I recently replaced the led stips on my TV. Got it all put back together and now I have other issues. What do I need to replace now?
Posted by Michael Crouch on
JonSnell Electronic
    Top Expert:
  • Televison & ... Master
  • 31,846 Answers
Could be T-conn board or maybe a new screen will be required as I would say it is damaged.
Posted on Jul 10, 2020
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: 42 tv issue
The part number you gave, 932222538682 is a pdp (Plasma Display Panel), and that's just the display panel of a Philips 42" Plasma Tv., which by the way has been substituted to Philips p/n# 932222695682 and is the most expensive part of the Tv- worth about $1800.00 dollars. Unless you have some grand design to be the first on your block to own the most expensive heath kit in the world I'd suggest you return it and spend your money more wisely on a unit already assembled..
Bill
Posted on Nov 15, 2007
Anonymous
  • 125 Answers
SOURCE: Mitsubishi WD-62525 Red Status Light After Cap Replacement
maybe this help you, let me know. good luck
ok here new tips on v26 chaiss cust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
Posted on Sep 10, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Posted on Sep 11, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Problem with Mitsubishi 52525 TV
A teady blinking green Led is usually caused by the foru 1000uf 16V capacitors on the DM pwb
Posted on May 24, 2009
intk50
  • 84 Answers
Mitsubishi V26 error code 41 with solid red status indicator is caused by leakage from capacitors C9A37 and C9A38 (3300mf/16v). The result is a bad fuse F9A02 (15amp pico) which reports error code 41 indicating short protect. The Mits part number is 283P144040 but any PICO 15a fuse will work.
Bill W.
Integrityhomeworx.com
Posted on Mar 14, 2011
I have a Vizio M550VSE tv and for the life of me I can’t fighre out what’s wrong with it. The issue I was having is the screen would just flash when turned on and then go black. It pssed the flashlight...
It could be a bad connection that shows up when the screws are tight that hold it together. Put one screw in, test, next screw, test, etc till you find the one causing the issue.
Nov 13, 2017 | Vizio Televison & Video
I have an LG 47LN5750 LED TV. I have replaced both the TCON and Power Supply boards. The picture came back for a few hours after each board was replaced but when i switched the TV off and back on again...
Hi Kelly,
Yes there may be an issue with the backlights. Some joint or connector in side may be heating up and causing this trouble. There may be some corrosion on some connectors also. It a delicate and risky job opening the panel and checking it. Only an expert must attempt it.
Good luck.
Aug 09, 2016 | LG Televison & Video
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
Jun 22, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
LED tv backlight issue
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 17, 2016 | LG 42LN541C - 42" Class 41.9" viewab LED...
After replaced the LED strips in my TV, I see a checker-board pattern on the screen.
It sounds like you didn't get the diffuser sheets back on in the correct position, so it is not spreading the light correctly. Please keep in mind how fragile these are and the importance of not letting any dust in between the sheets. I wish you well on this endeaver.
Apr 12, 2016 | Samsung Televison & Video
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Sony Bravia KDL-40V300 won't turn on.
Unfortunately 5 blinks is a LCD panel error. The only way to fix it is to replace the whole LCD panel. This is the most expensive part in the TV.
part number: 1-802-488-12
List price: $1336.32
Core charge: 1790.00
You could try to replace it yourself but would need to take the whole TV apart by first taking off the back cover, then removing all the boards in order to get to the panel before putting it back together but I would just recommend buying a new TV as the price of the repair exceeds the price of a new TV of the same size.
Oct 13, 2009 | Televison & Video
May 24, 2009 | Mitsubishi WD-52528 52" Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
