Creative speaker a320 din 9 pin connection - Audio Players & Recorders
Posted by Kaka Reddy on
Subha Dhar
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
This speaker is very good.
Posted on Jul 06, 2020
  • Kaka Reddy
    Kaka Reddy Jul 06, 2020
    its not on the quality of speaker, i wanted help on DIN9 pin connection.
What is 9-pin DIN pinout?
A DIN connector is an electrical connector that was originally standardized by the Deutsches Institut f?r Normung (DIN), the German national standards organization. There are DIN standards for a large number of different connectors, therefore the term "DIN connector" alone does not unambiguously identify any particular type of connector unless the document number of the relevant DIN standard is added (e.g., "DIN 41524 connector").
th?q=9b+pin+din+connectors&w=100&h=100&c=1&rs=1&qlt=90&pid=inlineblock&mkt=en-ph&adlt=moderate&t=1&mw=247 this is just a sample image of 9 din connector
Feb 16, 2016 | Altec Lansing Acs340 Computer Speakers
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
Dec 15, 2013 | Creative Technology SBS A200 2 Speakers
Subwoofer not working
what is the name of the connector? i read somewhere that is a female db-9 but that is the serial port
Nov 04, 2013 | Creative Labs Audio Players & Recorders
I have harman karden subwoofer but i dont have any
hmmm....does the subwoofer have any controls on it or are the controls on the speaker that came with the sub?
Jul 30, 2013 | Dell HK395 Computer Speakers
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
My woofer is not working as if there is a short somewere it comes on then when moved it goes back off
sounds like the contact points on your 9 pin DIN connector are corroded. If carefully cleaning each pin sounds like too much work, a search on ebay for a male 9 pin mini-din might bring you joy. But THAT solution requires some soldering.
Jul 13, 2011 | Dell HK395 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
Feb 12, 2011 | Vizio 42 in. LCD TV
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
