Question about The Computers & Internet
Pans purchased in 1968, the bottoms are turning white instead of black. Is it safe to continue using them
Posted by Sheryl Jackson on
  • 1 more comment
  • Anonymous Jul 06, 2020
    all my pans drip grease , from stove.
    why not discover how to clean things,.
    no really.
    all my pans call the others black. pots and pans.
    oddly. not one is white, .
  • Andrew Taylor
    Andrew Taylor Jul 06, 2020
    Is that you Larry? Cooking skills as well :>) I think they are cast iron pans
    pans come on cast iron, aluminum, or SSD or copper clad, SST. (and more)
    no photos of your pans, how can any one guess what you have, lacking a simple photo posted.
    my wild guess ( useless) are Aluminum and parked in the basement are not corroded to aluminum Oxide, seen as white powder that rubs off, with a finger.
    that is what all old raw aluminum does, but not anodized alum. but if the that wears off , then it does corrode to. see AA on a screen door frame?
    why not clean them. why worry if not used to boil bug spray or melt lead that is..........
    hit it with Ajax and elbow grease, .
    and nobody eats off bottom of pans. do you?
    but do clean them or ask the maid.
Andrew Taylor
    Top Expert:
  • The Master
  • 33,373 Answers
Yes, because your food does not come into contact with the outside.
If they are cast iron, you can spray the bottom with 'Easy Off' oven cleaner, put them in a bag and leave it for a couple of hours and the rinse off, scour and re-season them.
Posted on Jul 06, 2020
How do you make basic white sauce?
It begins with 2 Tablespoons of butter and 2 Tablespoons of All purpose flour. First you melt the butter in a sauce pan on low to medium heat. When it is melted add your flour and stir until it becomes completely combined. Then slowly add 1 cub of milk ( I use whole milk for this recipe, I have never used any other type of milk for my sauces) constantly stirring. You will notice that it will begin to thicken. If it feels as if it's sticking to the bottom of the pan remove it from the heat and continue to stir until it's as thick as you wish it to be. You can put it on and off the heat (still stirring) as often as you need to.
Aug 19, 2017 | Cooking
I have a Samsung R720 and after reinstalling the OS the sceen stays black. I can hear the sound of windows logging on but I cannot see a thing. While reinstalling the OS the screen zorked but it had a...
I suspect your VIDEO DRIVER or some APP(S) are not installed correctly?
Turn on and use safe mode
  • Turn the device off.
  • Press and hold the Power key.
  • When Samsung Galaxy Avant appears on the screen: ...
  • Continue to hold the Volume down key until the device finishes restarting.
  • Release the Volume down key when you see Safe Mode in the bottom left corner.
  • Uninstall apps that are causing a problem:
Here is a FORUM that will/should help you!
Anthony
Root Safe Mode what does it do
Dec 11, 2017 | Samsung Computers & Internet
Where do i find a 1968 volkswagen frame
1968 VW cars did not use a frame. The body and floor pan were welded together.
May 14, 2013 | 1995 Volkswagen Cabrio
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I have an hp min 10 i netbopok , i try to turn it on , but when it goes to that windows xp page with the little black bar at the bottom, it will then flash to a blue screen w/ white writing and then go to...
Hmmm... Have you updated your driver recently or installed any new software?
If then, you are seeing options to go to safe mode na? Go to safe mode and open "system restore." Try to restore to some near date.
Aug 12, 2010 | HP Mini 1000 Netbook
Laptop in continual stop start cycle
please the memory RAM with the same type and specifications.
Sep 24, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
I need to remove small stones from bottom of dishwasher
can you use tweezers, or needle nose pliers, or a hemostat, or even tape on a stick?
Mar 23, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Microsoft Streets now in black and white instead of color
the trial period is expired and stored the information in your computer's registry now u have to install a purchased version.
Nov 21, 2008 | Microsoft Streets and Trips 2008 for PC
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
