Question about Garden
What is the spreader attachment used for on a serger
Posted by Sandee Heldt on
Tom Chichester
    Top Expert:
  • Garden Master
  • 55,953 Answers
It flattens the material.
Posted on Jul 06, 2020
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
Serger spreader won't stay in
the stitches will not lock together, it may be timing is off.
Apr 07, 2013 | Singer 14SH654
I need to know the spreader settings for my Agri Fab dry speader model #45-03152
Jeremy the settings to use, are usually listed on the bag of fertilizer.
http://www.agri-fab.com/utilities/support/manuals.aspx
Agri Fab Model List and Online Parts Diagram
Aug 28, 2010 | Agri-Fab Agri Fab Spreader
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Spreaders how does it work?
An axle or “beater bar” is located inside the bin next to an open slot in the floor. Attached to the axle is a series of beater arms or paddles. When the axle turns, the paddles break up the material and direct it toward the opening where it is deposited evenly on the soil.
Aug 27, 2008 | Earthway 2000a Deluxe Set Up 40 Ib....
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
