Question about Garden
I need the instruction manuel for outsunny 10 x 10 aluminum frame poly carbonate hardtop gazbo , model#01-0871
Posted by Beverly Tucker on
Andrew Taylor
    Top Expert:
  • Garden Master
  • 33,301 Answers
Amazon Review - The manual is BAD!
Paul Sisk3.0 out of 5 stars Extensive multi-part review
Reviewed in the United States on April 19, 2019 Verified Purchase
I will be doing this review in several parts. I am starting off with 4 stars due to the very bad install manual. It is all stick pictures of the installation steps (aside from warnings on page 1). For the people who rely heavily on words for the install, good luck.
The 1st part will be the delivery, unboxing and initial take on the quality of the components as I take them out of the box.
The 2nd part will be the actual building of the gazebo and thoughts on that as I go.
The final 3rd part will by overall summary of the product and experience as a whole.
It is going to be similar to this
https://secure.img1-fg.wfcdn.com/docresources/30396/37/371842.pdf
Videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01mKVYWDrsA5j98w93L3ap5yYeHPg%3A1593976684729&ei=bCcCX7WFLJCkytMP-fu_-AM&q=Assembly+instruction+outsunny+10+x+10+aluminum+frame+poly+carbonate+hardtop+gazbo
Posted on Jul 05, 2020
Terry
  • Garden Master
  • 11,377 Answers
Contact manufacturer for assistance through their web site:
https://www.aosom.com/item/outsunny-10-x-10-steel-and-polycarbonate-hardtop-gazebo-canopy-cover-with-mesh-net-curtains~01-0871.html
Negative comment at web site below suggesting poor instructions and problem assembling.
https://www.wayfair.com/outdoor/pdx/outsunny-10-ft-w-x-10-ft-d-metal-patio-gazebo-otsu1638.html
1 Related Answer
Michial Gueffroy
  • 1140 Answers
SOURCE: HOW TO GLUE POLY CARBONATE
You might try using two part epoxy. It comes in two tubes and you follow directions to mix one drop of each together to make the epoxy to use to glue the parts together. For best results the parts glued together shouldn't be disturbed for 24 hours. I have used the Locktite brand with good sucess.
Posted on Apr 29, 2009
We ordered an Outsunny Three seater Outdoor swing Canopy a few days ago the product has arrived but with five pieces missing basically the main frame Russell Beer
Hello, Russell -
Fixya.com Answerer, Brett Duxbury, may be correct in that the missing parts may have been shipped in a 2nd box.
If you purchased the swing new, there is probably information with the assembly instructions regarding missing parts and contacting the company which manufactured or distributed the swing. Check for such information.
If you cannot find it or if the swing was purchased second-hand, contact the business from which you purchased the swing or the individual seller and ask for the missing parts or arrange to return the partial swing kit for a full refund. Ask to have your return shipping cost reimbursed, too.
Apparently Outsunny is a trademark of a company headquartered in China:
Ningbo MH Import & Export Co. , Ltd.
Ningbo, Zheijiang Province, China
I see that Outsunny patio and garden furniture is sold by a number of different businesses in several different countries.
Without knowing the country where you reside and the business or seller you purchased the swing, I cannot direct you to a viable source for the missing parts.
Best wishes.
Apr 26, 2018 | Garden
GREENHOUSE ASSEMBLY
Request assembly instructions directly from OUTSUNNY.
Apr 07, 2018 | Miscellaneous
Outsunny 158" manual awning installation instructions.
Request instructions from Outsunny.
Jan 30, 2018 | Garden
Tent instructions for the Outsunny 32x20 carport
Request the instructions directly from Outsunny.
Jul 28, 2017 | Sport & Outdoor - Others
Replacing poly carbonite panels
The panels are replaceable from the manufacturer, which differs depending upon your date of purchase. I purchased my gazebo from Sears in 2013 and the manufacturer is Sojag, located in Quebec Canada. The panels cost of $328.00, which included tax and shipping. Their web site is www.sojag.ca and their customer service number is 1-450-659-4402 (there is an 800 number but I don't have it in front of me at the moment). You will need to have the model number of your gazebo available when calling so they can verify whether it's one of their products.
Jul 02, 2014 | Grand Resort Collection Hardtop Gazebo...
I can't get the bike seat stem to come loose
I'm going to assume you that when you say, "bike seat stem" you mean "seat post". I'm also going to assume that the bike frame is made of steel and the seat post is most likely chromed steel.
What most likely is the problem (absent of more details) is that the seat post has rusted to the inside of the frame. If the bike is stored outside this is a very common problem on less expensive bikes.
I have never heard of a bike manufacturer putting any kind of paint or other anti-corrosion inside of the bike frame to prevent rust.
You can try spraying a little "Liquid Wrench" or WD40 oil on the seat post where it inserts into the frame. Let it sit over night and then tap it with a mallet to try to break the rust free. Use a pair of Channel Lock pliers to get a bite on it and see if you can twist it out.
On a steel bike the very last resort to use, if you by all means have to have that seat post out, is to apply heat to it, with a propane or oxy-acetylene torch. This will probably destroy the paint job and weaken the seat post.
If the bike frame is aluminum, you can get something similar to galvanic corrosion and this can seize the seat post in the frame. The remedy is the same as with the steel frame (but excessive heat and easily melt aluminum very quickly and leave a puddle of molten metal on the garage floor). If the frame is carbon fiber and the seat post is aluminum, carbon and aluminum don't like to touch each other and they will start a natural chemical reaction of corrosion which could cause the two to stick together (don't ever use a flame on a carbon fiber bike, it would be the end of the bike and just plain stupid). Anytime aluminum touches carbon or titanium an anti-seize compound should be applied to the parts.
Once you have the seat post removed, use your finger to wipe grease inside the seat tube and on the seat post before reinserting it and you won't have this problem again.
Aug 30, 2010 | Bike Extreme Lite Youth Shoulder Pad
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
