Question about Maytag Dryers
Maytag dryer quiet series 200 trip the breakers.
Posted by Manny Baez on
Mark Lubinski
    Welcome Back:
    Visited the website for 2 consecutive days.
It depends when it trips the breaker.. At the very beginning or when heater comes on. Check this article to determine an issue: https://howtofixit.net/what-to-check-if-your-dryer-keeps-tripping-breaker/
Posted on Jul 15, 2020
Tom Chichester
    Top Expert:
  • Maytag Master
  • 55,995 Answers
Could be due to a shorted heating element
Posted on Jul 10, 2020
5 Related Answers
Bill Johnson
  • 306 Answers
SOURCE: Maytag quiet series 200 Legacy not cleaning
under the unit where the water line connects,this is where the filters are.disconnect the water line take the fitting off that the line was hooked to,screen is there under fitting.
Posted on Jul 15, 2009
Anonymous
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Is there a reset button
Go to the electrical panel of the house or apartment and turn off the power to the dishwasher for two full minutes, then turn the power back on. This will reset it. J.
Posted on Sep 23, 2010
Anonymous
SOURCE: Maytag Quiet Series 200 Handle Broken
Remove the torx screws around the inside of the door and pop off the inside cover. Remove two screws and unplug handle. Remove broken handle. Insert new handle and replace screws.
Posted on Nov 11, 2010
Anonymous
SOURCE: my maytag quiet series 200
Mine would not start, and could not set any options. I read online to try resetting by pressing Heated Wash, then Heated Dry, then repeat both. I did it and my machine cleared and worked fine. Give it a try!
Posted on Dec 25, 2010
Maytag quiet series 200 dryer, runs.dries cloths,but timer does not move to time out through its cycles,like cool down and complete or finished.?
It sound like a bad timer motor.check with a local parts store for the replacement part and remove the screws from the top rear housing and you will see how to replace it
Feb 28, 2015 | Maytag Dryers
Maytag quiet series 200 runs, dries but timer does not move and time out.?
Probably the timer motor is broken, or electrical connection bad. Probably need a replacement timer. OR something has wrapped around the dial shaft and is binding the dryer.
I have a maytag quiet series 200 gas dryer that will not stay heated
replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Jan 11, 2013 | Dryers
MAYTAG QUIET SERIES 200, THE DRYER ISN'T DRYING NOT HEATING CLOTHES
this problem could be that the heating element in the dryer is not working and may need replacing
Aug 14, 2011 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
Keypad does not work
Time to buy a new one I guess.
Go check the fuse braker, it tripped probably.
Did you close the door properly , push it hard with a slam. It will start working. Jiggle the float inside the up and down.
Vitally
May 11, 2009 | Maytag MDB7100AWB Dishwasher
Apr 04, 2009 | Maytag Dryers
Dryers Logo
Top Maytag Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
