I have penasonic vk90d 7000W nothing is work only stuck on dvd changer. Nothing happened while press any button DVD AUX TAPE FM No on is work . sometimes the show F61 and some time never turn on only demo is start . Plz help me
Posted by Omar Chaudhry on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 33,442 Answers
*pAnasonic
That is a heavily over-engineered system and there is no way you are going to be able to fix it yourself. Take it to a Panasonic service centre for diagnosis and repair. Of just bin it and buy a sound bar.
https://datasheetspdf.com/pdf-file/607282/Panasonic/SA-VK90D/1
http://en.all-specs.net/model/9433/
Posted on Jul 05, 2020
5 Related Answers
Anonymous
SOURCE: DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Posted on Apr 07, 2007
Anonymous
SOURCE: dvd player stuck in 'demo repeat mode'
Hold the Stop button for 5 long seconds
Posted on May 06, 2008
Anonymous
  • 3 Answers
SOURCE: Tape is stuck in my Sony handycam DCR-PC101
I have managed to eject my tape by powering 4.5 V the little motor which drives the eject mechanism.
Problem is that you have to dismantle half the camera to do this (be very careful with the flexy wires they are fragile) and I wouldnt' do it without the service manual.
Posted on Dec 24, 2008
SOURCE: DVD tray will not open
I had the same problem - unplug first- it is easy to undo all 6 small screws - open it up -plug in and then you can give it a little help to open it. It worked for me, BUT now it will open and close but not play the dvd.
Posted on Jan 20, 2009
SOURCE: my panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Posted on Jul 13, 2009
While trying to convert a VHS to a DVD, both are placed into the converter and I press the button indicating the process to begin conversion from the VHS tape to the DVD, but when I press the...
The Sony SLV-D300P is a DVD PLAYER and VCR. It does not record DVDs. You would have to buy a combo unit with a DVD recorder, not just a DVD player.
Mar 14, 2011 | Sony SLV-D300P DVD Player/VCR
I have a pioneer mosfet deh-2900mp car stereo with cd and aux in the back, my problem is i can't get the aux to work i know it plays because it plays it over the tuner but i can't activate the aux...
radio off press and hold the audio, sound or info button
it only teks 3 to 4 seconds , the radio is goin gto turn on on menu mode, you have to find the cd changer and turn it off,also find the aux and turn it on
you can also turn on and off many other functions
it is only 1 button
good luck
Mar 03, 2010 | Pioneer DEH-P80MP CD Player
Range rover cartridge that holds dvd & cd's will not eject.
Hi, I am having the same problem with a RRSC that I have just purchased, the blue eject button on the boot mounted DVD changer lights up but nothing happens when you press it, not even the sound of things trying to happen... Did you get anywhere with your?
Dec 02, 2009 | Dual Car Audio & Video
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
5 cd changer tray wont open
just opened the dvd player..took out the jammed cd and it's working properly now...saved me 55$ for a check or was advised to buy a new one costing 400 odd $!
Jan 21, 2009 | Philips CDC775 5-Disc CD Changer
Tried the 543210 code but no menu appears , am i missing something
In order to acess the hidden menu you first have to first click the AM/FM button then on youre remote click the dvd setup button once there press 54321 listening to the beeps. Then hold 0 untill the hidden menu comes up
Dec 29, 2007 | Jensen VM9510 Car DVD Player
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
