SOURCE: digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
SOURCE: Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates' i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers. this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows. the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
SOURCE: LG 194wt
Did you check the energy saving settings for the monitor
The display settings in control panel should have a tab
for screen saver that also has settings for the monitor
power saver setting. If there is a setting for Digital Power Saving mode adjust it or disable it.
If this does not solve the problem then you may have to
disable APM in the bios setup
SOURCE: my LCD monitor is going into power saving mode
nothing to do with your back light.
PLEASE try another VGA cable
I say get a new vga cable and your troubles will be over,had the same problem with a dell lcd and a lg lcd new cable worked on both ! I know, how does a cable fail , who knows ? must of been a bad batch or something silly went on !
