Question about Lands Phones
Why has my bt4500 handsfree phone stopped beeping when numbers are pressed or returned to its base please
Posted by Marlene askew on
Don A
  • 2,710 Answers
3 Related Answers
Anonymous
  • 275 Answers
SOURCE: can't hear without handsfree, beeps
Hmm..did you try the customized profile so you can set it on the loudest mode? and also have you noticed if your phone makes any other noice like when you move around the menu or type a text messege? does it play music on the speaker? Try all possible ways you can think of that makes the phone create sound as a response. And last thing to do would be a reset.
  • Go to menu
  • Phone settings
  • Reset settings
Try this to bring the phone to factory settings, make sure you back up your information, like your contacts before, and good luck.!
Posted on Dec 13, 2008
Anonymous
  • 89 Answers
SOURCE: Uniden Dect 6.0, the base keeps beeping
You have your answering machine set up to beep when you get a new message. Go through the menu for setting up the answering machine and turn that feature off.
Posted on Apr 16, 2009
Anonymous
  • 337 Answers
SOURCE: phone says no link to base phone stop working
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
Posted on Feb 28, 2010
I have blocked a number by mistake, how do I unblock it?
Hi Kathleen, The link below is a user manual for a BT4500 CORDLESS PHONE.... The answer you're looking for is on page 28 When you enter the block calls list you can also edit or delete numbers you've stored previously by selecting and then pressing to display either and pressing Delete number You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
http://www.manualslib.com/manual/713677/Bt-Bt4500.html?page=1
Mar 31, 2016 | BT 4500 Cordless Phone - DECT - Satin...
How to re set phone
hi there more often than not phones like your Bt4500 have a battery that's installed inside the handset, now after long charge times and the handset being plugged in the base the battery becomes lifeless and faulty and dies, once a power cut happens as the handset has no longer got power the battery can not recover ! my best advice would be to open the back of the handset and locate the battery and replace with same from mapplins or ebay and give new battery a good charge this should get your phone working again
Mar 04, 2015 | Panasonic P-P301PA/1B Cordless Telephone...
How do i store numbers in my prolectrix big button speaker phone please
  1. Lift the handset or press the Handsfree button.
  2. Press Store/memory.
  3. Press the 0 - 9 buttons you want to use as the memory location.
  4. Enter the phone number you want.
  5. Press the Store/memory button to confirm. You hear a confirmation beep. The number is stored.
Aug 01, 2010 | Big Button REIZEN Speaker Phone -...
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Cordless GE phone issue. 25825GE3-A
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
Would like to record greeting
Here is a link to the instruction manual (5.06MB): http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2. Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep. Sample Outgoing Announcement Hi, this is (use your name here), I can?t answer the phone right now, so please leave your name, number and a brief message after the tone, and I?ll get back to you. Thanks. Reviewing Announcement ? Press and release the announce button to play your outgoing announcement.
Mar 04, 2007 | GE 25881EE3 Phone
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
