Question about Garden
Do I put oil in the gas???? Yes or no - Garden
Posted by Robert Robbins on
Andrew Taylor
    Top Expert:
  • Garden Master
  • 33,434 Answers
We aren't mind readers, we have absolutely no idea what you have!!!
On most small garden items like trimmers and chainsaws, yes. On mowers with 4 stroke engines, no! Does it have valves? Valves mean 4 stroke, no oil, No valves means 2 stoke, so oil mix.
Google
make model manual
or
make model gas oil mix
Old ones are 20 or 25 to 1, modern are 40 to 50 to 1.
Posted on Jul 04, 2020
Putting my yard king 8/27 snowblower away for the summer. Should I remove the gas and oil. If yes, how?
I do not live up north or where there is so much snow, but I think you should drain the gas and oil from your machine.
Do you still have your owner's manual? Check it for directions.
May 13, 2017 | Garden
I didn't realize that my Ariens 522 2 cycle snowblower is a oil/gas mix. I filled my tank full with just gas and no oil. Can i just add in oil and manually mix it?
Yes, you can. I thought it was a chain saw, but you can shake a snowblower :>) Put the oil in stir vigorously with a spoon.
I changed the category.
Dec 12, 2016 | Garden
What oil to use for a yardworks gas mower 060-1648, 060-1649, 060-1658
Hi , There's two different types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) Ask at the local lawn mower repair store for the oil type and the 2 stroke grade, it's just two stroke oil you add to the gas (2 stroke mowers ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then NO you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
http://bpretail.bp.nl/australie/2_stroke_brochure.pdf
May 10, 2016 | Garden
What type of oil do I put in?
Hi Shelly, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
Mar 30, 2016 | Garden
How do you put the oil in? seems to suggest to put it in the gas tank. How much?
Hi Barry, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
Mar 27, 2016 | Garden
Problem with Lawn Trimmers & Edgers I put a
Yes, this should not hurt it, just clean the plug and crank until it fires up, it will smoke until the oil has gone. Are you sure it is a four stroke machine?? as most are two strokes and do require a fuel/oil mix.
May 14, 2013 | Garden
203 ktm 125sx do i mix oil with gas when i put gas in it?
yes you do,buy a good quality synthetic 2 stroke oil and then mix at between 32 to 1 to 40-1 fuel mix ( 40-1 is 40 litres petrol and 1 litre oil)
Aug 31, 2010 | KTM SX 125 Motorcycles
I have a 110cc panther atv do i need to put fluid in my crank case
yes - all gas motors need oil in the crank case - it should say on the engine either ( cc or ll ) for the amount of oil to put in - 20-40 oil type.
May 21, 2010 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Homelite broom help I put way too much oil in now it's smoking!
i agree finding the ratio is no as easy as it should be. yes. drain the tank. don't use the old gas somewhere else. use fresh gas & mix ratio in separate gas can or container. use a bit of ether/starting fluid into the air-filter inlet opening help fire it up. a new plug is fairly low cost and easy and that might also be needed after the oil bath and 3 years.
Nov 03, 2008 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
