NO PC told. no OS told no monitor screen told if a Desktop PC.
what does 7060 mean"? (wild guessing...) DELL ?Micro Optiplex 7060,??? micro, SFF?, or tower? if the PC is ok and the monitor fails on a 2nd PC the monitor is no good. Using same cable)
if the monitor is 2010 or older it has CCFL lamps inside and more now are dead. or wildly intermittant. CCFL tubes: dead.,dim, flash, yellow tinged, or random. do not use old monitors that old is best practice, cost to fix it is more than buying refrub monitor.NO PC told.
no OS told
CCFL tubes:
You can't post conmments that contain an email address.
Hi, Following is Vizio parts dealer, please contact for required lcd screen...
Encompass Inc. 7060 State Road 84 #12 Fort Lauderdale FL 33317
Call: 954-723-9191 and 800-432-8542
Thanks.
Call: 954-723-9191 and 800-432-8542Thanks.
check the drum, remove it and and check if the connector of the drum to the printer is ok, after returning the drum to the printer turn off your printer remove the power plug from the wall outlet and same also at the back of the printer. after five minutes power on the printer.
I replaced cord with metal wire aprox. 2 inches long and reattached cord to that. The metal grill wears out the rope. Of course you'll have to take it apart to get to switch.
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here: http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
oh sir ur cell nead a flashing
that is the proses to download the operating system like pc format
for the flashing u have to have M.T, box that cost near about 5000Rs/- so i advise to u to go nearest service center ok bye sir
NO PC told.
no OS told
CCFL tubes:
