Question about Maytag Refrigerators
Maytag Refrigerator MF12568AES -two temperature windows say off. can't get any buttons or controls to work.
Posted by Lou Barrett on
ray gallant
    Top Expert:
  • Maytag Master
  • 68,537 Answers
Contact maytag service we do not know all we possibly could
Posted on Jul 05, 2020
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Temperature Control
call the number in your service manual. they'll ask you to sent the receipr, the silver sticker on the back of the fridge, and a piece of the outlet cord so they know it's not in use. they'll ship you a new fridge. WOW!
Posted on May 17, 2007
Robert Hirst
  • 833 Answers
SOURCE: Maytag Refrigerator MFC2061HES - temperature control
Maybe. Is the compressor staying on? If it is...then the temp controller may need to be replaced. If it is cycling regularly, then you are iced up and the controller can't do much to help you. Fully defrost. Takes 2 days to melt it all. Then let's see where we are.
Posted on Dec 23, 2007
Anonymous
SOURCE: MAYTAG refrigerator (MF12568AES) entering code
Call Maytag. They are aware of the problem. When I called them last year, they sent me a new control board for free, but they didn't provide labor. We got someone out here to install the new board thru our home warranty. We paid $65 for the labor. Not sure how much Maytag will charge.
Posted on May 18, 2009
Anonymous
SOURCE: My Maytag MF12568AES Refrigerator is not cooling
This happens to my Maytag like clockwork every summer. The freezer works fine but the refrigerator stops cooling. The first time this happened, it was the fault of the small plastic DC fan that sends cooling from the freezer compartment to the refrigerator section. A technician replaced the DC plastic with an AC metal fan he guaranteed would last the life of the refrigerator. He blamed govt energy standards as the reason Maytag uses the cheap DC plastic fan in the first place. Problem solved. One year later, same issue with no cooling in the refrigerator, freezer fine. Again today, nearly one year to the day! SOLUTION? Trip the circuit breaker or unplug the refrigerator for a minimum of 5 minutes. A reboot now fixes the problem every time. Who would have thought you'd ever have to REBOOT your refrigerator?
Posted on Jul 16, 2010
geoff hunter
  • 4793 Answers
SOURCE: I have a Maytag model mf12568aes
if water stays still long enough it will release a small amount of air,and it sounds like you have an air lock.first try to run as much water as you can to see if that fixes it otherwise its a clip/pipe off job.
Posted on Jul 30, 2010
How old is my Maytag refrigerator?
OCT. 1982... See link:
http://www.applianceaid.com/age-maytag.php
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 21, 2014 | Refrigerators
HOW DO I ACCESS THE CONTROL PANEL ON MY MF12568AES
You probably need a new control panel - need to call your home warranty (if you have one) or call Maytag. Can only get one thru them.
Jun 08, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Handle on the freezer door has fallen off maytag model mf12568aes serial 12384967lp
If handle is right behind gaskets then pull gasket a little and you should be able to get it
Dec 12, 2017 | Refrigerators
My Maytag MF12568AES Refrierator control panel flashes on and off and the door flapper to te ice maker opens and closes uncontrolably. Whats up?
this is a very common issue the control board on the back of the unit is bad, you will need to replace it to fix this issue, let me know if you need more help,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Maytag model mf12568aes refrigerator---when I use the water it pulses and there is a knocking noise in the refrigerator ---the ice maker works fine
Jul 30, 2010 | Maytag Refrigerators
My Maytag MF12568AES Refrigerator is not cooling. May be I need to reset the computer.
Jun 15, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Need filter#
We have parts for you! Email or call me and I will get the correct filter to you right away. 9728592929. I will need your address and it will be on it's way to you. Hope this helps.
Sep 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Aug 22, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
