Question about Sport & Outdoor - Others
I have a older Aztec cabin style tent item# 188 size 7x7 by academy Broadway and need to know the directions for sitting it up and the type of poles required , this tent was my father's and not sure which poles go to it in his garage
Posted by kevin bolejack on
ray gallant
    Top Expert:
  • Sport & Outd... Master
  • 68,557 Answers
YOU HAVE POLES TEST THEM UNTIL YOU FIND THE RIGHT ONE . WE CAN NOT DO THAT FOR YOU
Posted on Jul 03, 2020
1 Related Answer
Tom Chichester
  • 55983 Answers
SOURCE: I was given a Academy Broadway Corp. QUICK FRAME TENT Item 10210 but no instructions for the pole assembly was wondering if you could help me with this problem. THANK YOU
Contact Academy Broadway directly to request instructions.
Posted on Jun 19, 2017
Need assemble instructions for A cabin tent
Go to mfg for manual download or try a google search for it. It will have assembly instructions.
Sep 20, 2017 | Sport & Outdoor - Others
Tip
HOW DO I PUT UP A TENT
Don't panic if you've never pitched a tent before. It seems scary when you first get started but with a bit of practice you will be doing it within minutes.
The most important thing is to practice putting it up before you go on your camping trip. There's nothing worse than the sun setting and no light left around you as you struggle to pitch your tent.
Here are my tips to help you get started: Make sure the area where you want to put your tent is clear, without any rocks or big bumps underneath, otherwise you won't be comfortable.
Don't pitch your tent on a low lying ground. If it rains - your tent site will be flooded.
To protect your tent you should lay a groundsheet down as tents can be damaged by punctures and moisture. Now take out the poles and insert them into the proper sleeves of the tent. The instruction manuals are usually pretty straight forward and helpful. Place both ends of the pole in the metal rings and the poles with flex as the tent begins to take shape. Straighten the tent by pulling the material straight and making sure the poles are stretched taut to the outer point. Now secure the tent into the stakes at the corners. Make sure they are really firmly in the ground so they can resist wind and being knocked into.
on Aug 20, 2012 | Camping, Backpacking & Hiking
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
Replacement Pole for Coleman Oasis Cabin Tent model 2000000583
Coleman may be contacted toll-free at 1-800-835-3278. Replacement parts are available from them.
Apr 01, 2014 | Coleman Outdoor Products Coleman Oasis 16...
I have an older 3 man dome tent that I would like to give to 3 little boys to play in but I cannot find replacement poles for it. It is item no 184. Can you possibly help me?
There is no way to help without knowing the brand and model of the tent. If it is older, then it is unlikely that poles are available, and if they are then they likely cost a surprising amount.
I recommend that you consider this to be a good idea, and a great intention, but that you also be prepared to dump the tent.
Jun 26, 2013 | Camping, Backpacking & Hiking
I have a magellan yukon (23-010) 20'x9' that has some broken poles. Where can I replace the poles
You can replace tent poles. I've never used them, but you can try http://tentpoletechnologies.com/. Otherwise I would suggest buying replacement poles from Academy (who makes the Magellan Outdoor line) or trying to find generic poles and an sporting goods store. Best of Luck!
May 31, 2013 | Magellan Outdoors Yukon II Cabin Tent
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
Jul 06, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Sport & Outdoor - Others Logo
26 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
