Question about The Computers & Internet
HAMILTON BEACH MW - Model: EM145AAK-P (Under license to and sold by Walmart) ... Clock Setting per Owners Manual: (1) Press " CLOCK ," "00:00" will display. (2) Press the number keys and enter the current time. For example, to set the clock to 10:12, press "1,0,1,2". (3) Press " CLOCK " to finish clock setting. ":" will flash and the clock will be lit. COMMENT: Clock is NOT able to be set per the aforementioned directions. Per online research, later confirmed by Walmart Customer Service (NOTE: Was referred to said Customer Service by Hamilton Beach Customer Service per licensing agreement), Step (3) of Clock Setting procedure was printed in ERROR and should have stated “Press ‘START’ to finish ...” instead, which, upon trying is also NOT able to set the Clock. QUESTION: Is there an alternative method for setting the Clock?
Posted by S J Mansfield III on
  • 9 more comments
  • Larry Ng
    Larry Ng Jul 05, 2020
    ok, you posted microwave oven to computer repair help?
    why in the world ask this here, and not in ovens here or better x100 better ask the maker for help.
    https://www.hamiltonbeach.com/search-res...
    it is not A COMPUTER,
    it is and OVEN Uwave
    https://www.walmart.com/ip/Hamilton-Beac...
    cheap Uwave ovens made in china.
    with bad operators guide.
    the manual is there, and states
    on my, oven, it is GE,
    one extra step is needed.
    1-clock
    2: set time by hand.
    3: push a/m p/m button.
    4 :push clock
    (GE only)
    not button clock starts the event and terminates the setting event.
    your manual states, page 10 this.
    2. Clock Setting
    (2) Press the number keys and enter the current time. For example, to set the clock to 10:12, press " 1,0,1,2" .
    (4) If the numbers are not within the range of 1:00-12:59, the setting will be invalid until valid numbers are input.
    Note:
    1. In the process of clock setting, if the " STOP/CLEAR" button is pressed or if
    there is no operation selected within 1 minute, the oven will go back to the previous setting automatically.
    2. If the clock needs to be reset, repeat steps 1- 3.
  • Larry Ng
    if this fails, unplug the oven for 1 hour.
    let it sit 100% dead , no AC power.
    them AC cord back in to all jack, and set time.
    if that fails send it back to walmart, for 2nd oven. if that fails, upgrade time.
  • Larry Ng
    more. ?
    plug in OVEN to wall jack AC.
    push closed the door 2 times, make sure nothing jamming door preventing said closure, fully.
    then push stop/clear button.
    next push clock ( if too slow it times out)
    and key in 1200 , (you must see 1200) and last clock button, does that work? (or 1159)?
    if it does not show what you typed. then it was typed in wrong or the #buttons are bad.
    try other time settings to prove that.
    like 1000 or 1111
    or 0200 or 200 or 300.
    one will work , keep in mind the firmware inside things like this are ddummbb(sic)
    it only allows a narrow rang of inputs.
    0-9. (never 9999)1259 is max.
    try more simple settings like I stated above.
    I can see it does not allows starting to cook
    at 11:30pm to 11:45pm, it is a cheap model
    with no am/pm nor 24hr military time modes.
    setting it is more simple than mine.
    clock +time+clock
    also what time setting did you try?
    clock 1100 clock
    clock 1100 start
    what? exactly tell what you did and exact displayed results for best answers.
    the manual is there on the walmart page.
    if all fails exchange it.
    its not big , and exchanges easy.90day rule.
    per manual. last page.
  • Anonymous Jul 05, 2020
    my GE will not ever work (cook) if the clock is not set first. so yes, if true that is a pain..
    is this old Uwave? yes/no? google finds nothing much.
    why post to computers and is not.
    post here.
    https://www.fixya.com/troubleshoot/brows...
    with door closed, try.
    clock (time)clock.
    clock 1111 clock , if this holds time. then the
    even works and you are not doing time correctly.
    there is no TOD battery backup , either like seen on all PCs made and all bedroom clocks.
    it forgets the second the AC power goes dead or the AC power in you home is interrupted.
    surges or near by lightning.
  • Anonymous Aug 07, 2020
    take it back to walfart and buy better brand.
    GE is one. KitchenAid.
    my GE ran for 15 years, until switches failed.
    replaced them for $20 and good for 15 more.
    nothing man makes last long + entropy.
    seem your UWAVED is by underdogs in (12,000 away) and junk, or can not translate to English. sad no?
    this uwave is contracted by walfart.
    sold only by wally.
    and is junk class. (bottom of the barrel cheap)
    that too means the manual with it is wrong
    google can not find one, . yeah rare.
    did you just buy this Uwave that it?
    or is it old?
    parts for it are rare, walmart only version. EM = that.
    clock (time) clock, say the manuals.
    if the numbers are not within the range of 1:00-12:59, the setting will be invalid
    as a test press 1111
    takes only 1 key number to do that. easy
    clock 1111 clock.
    just as a test to prove it works or not.
    this Uwave does not do milatary time nor
    AM/PM just like wall clock does with hands on face. 1 to 12.
    my GE does Am/PM.
    next time post here, not to computers.
    walfart ovens have poor support avoid them.
    we can not get or Uwave oven to work on wifi either, and are flummoxed.
    nor read our emails..
  • Anonymous Aug 08, 2020
    the microwave oven must not be faulty, not bad in any way or the OVEN brain blocks you ! .
    that is what it does, for sure if door not closed or the 3 or 4 door switches do not agree.(to each other or are INTERMITTENT)
    that is how they work, to prevent USER injury.
    they are called fail safe interlocks.
    if this OVEN is not new, say so, even tell how old it is or even last time it worked, right.
    never, or just found it at a garage sale.
    HISTORY MATTERS< for sure.
    why not post to ovens here, and not computers.
    post using the correct forum and answers go 10x faster and 100x better.
    for sure.
    I think oven logic works in this way
    power up. wall plug.
    clock glows, & must be set first. (rule1)
    but , the logic checks that there are no faults in the oven door, or overheating sensors.
    if it sees any error at all it will not let you set the clock, on some Uwaves it even blows the main fuse inside to prevent (on purpose) users getting injured. (serious this is, )
    Next time buy a real uWave oven from a top maker so support is 10x better, not ever buy walmart custom brands as you did. (horrible support)
  • Anonymous Aug 09, 2020
    It does need service for sure,
    2000 volts inside and lethal so not YOU.
    sure does.
    signed Mr.Captain Obvious esq.#3
    send it back to walfart, sure.
ray gallant
    Top Expert:
  • The Master
  • 68,634 Answers
And how would we know as never owned one
Posted on Jul 05, 2020
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
oldnovii
Jeffrey Pemberton
  • 667 Answers
SOURCE: HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/bpia5305.pdf
Jeff
Posted on Apr 30, 2008
Anonymous
  • 65 Answers
SOURCE: color tv service mode
Change Memory IC
Posted on Oct 07, 2008
Anonymous
SOURCE: i need my smart movie 4.0 license key my device serial number is
my device serial number is 355718022288839 i want to
Posted on Jul 17, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
How to set clock Hamilton Beach microwave
Try Googling (Hamilton Beach)(model)(manual) without parens to get instructions.
Oct 09, 2017 | Hamilton Beach Microwave Ovens
How do I set the clock on the hamilton beach microwave
Google (Hamilton Beach)(model)(manual) without parens to get instructions.
Feb 03, 2017 | Hamilton Beach Microwave Ovens
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
Display clock on phone
I found the answer at www.digcom.com.
CLOCK/CALENDAR SETTING
Note: The date must be set in system programming (10-01).
To set the system Time:
1. Press the Speaker key.
2. Dial 728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press Speaker to hang up.
Aug 05, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Computers & Internet Logo
187 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
