Question about Garden
2013 Huskee LT 3800, MD# 13A276LF031 with Power More 420cc engine MD# 4P90JUB Riding lawn mower runs for approximately 10 t0 15 minutes before shutting off. HELP! Thanks
Posted by Lucian L Thompson on
Carl Rock
  • Garden Master
  • 2,452 Answers
Multiple causes;
Fuel tank vent. Loosen tank cap and see if problem goes away.
Failing ignition module. Check for spark at time of failure.
Failing afterfire solenoid. Removed solenoid and detach plunger and see if problem goes away.
Posted on Jul 03, 2020
Testimonial: ". I have replaced starter, carburetor with fuel solenoid, new Coil, fuel filter with arrow pointing towards the motor, new gas lines, new spark plug, gas tank with new breather attached, replaced oil filter and changed oil. New air filter. Not sure but think the kill switch wire from coil gets too hot lying on motor and shuts me down. Or fuel stops getting to carb"
  • Carl Rock
    Carl Rock Jul 03, 2020
    Multiple causes;
Looking for a LT 4200 huskee manual
Operator Manuals
If you don't find it, give them a call.
Also, here is a link for parts manual online:
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13w2775s031-lt4200-huskee-lawn-tractor-2013/
Apr 27, 2017 | Garden
My huskee Lt 4200 riding lawn mower was running and just quit, now it won't start the starter engages but won't turn over.
try to turn the engine over by hand on top of the motor. if it is stuck it sounds like the engine may have locked up. make sure the starter is'nt stuck on the flywheel.
May 25, 2016 | Garden
420cc powermore ohv
I don't find any reference to an oil sensor on the 4P90JUB.
Aug 08, 2014 | Mtd Garden
I have a huskee lt4200, engine is a 420cc OHV.
Check for gas contamination in the oil....if the oil itself it gas free....its likely a blown headgasket.
Aug 05, 2013 | Briggs & Stratton Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Apr 10, 2010 | Garden
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
