Dryers Logo
Ajsystems Posted on Jul 01, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i have a maytag dryer mde3000ayw not starting. considered buying a used dryer but determined to fix this instead.. or atleast try. Here are a list of some troubleshooting I've done
- Verified outlet has 240 volts (2 x 120) - removed the cycle dial knob and verified its getting power (2x120) - checked for continuity when dryer is set to normal dry setting - checked the start button for continuity/0 ohms. (removed the wires and pressed the button) - checked the door button for continuity when pressed - checked the thermal fuse for continuity - checked two other fuses by the motor for continuity and they both seem fine. The Dryer doesn't do anything when plugged and start button is pressed. any help is appreciated
David Spradling
Level 3:
Top Expert:
  • Maytag Master 13,520 Answers
  • Posted on Sep 11, 2020
David Spradling
Maytag Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
927684
Points
28384
If voltage past switch bad motor
Kenneth Simmons
Level 3:
  • Maytag Master 1,239 Answers
  • Posted on Jul 01, 2020
Kenneth Simmons
Maytag Master
Level 3:
Answers
1239
Questions
Helped
751791
Points
4061
Maytag neptune dryer model mde3000ayw wont start
If it only runs with start button held in then you have a problem with the door switch. Check to be sure the wires are on it. Here is the switch to order in case it is bad.
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 05, 2011 • Dryers
1helpful
I have a Maytag Neptune MDE3000AYW serial no. 12307603UU. The dryer will not turn on. I can hear the timer clicking but when you push the start button it will not start. The door is closed. I have...
heatman101
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
1helpful
Squeeky noise in the back of dryer when running?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Maytag MDE3000ayw. When I press the start button, there is a humming sound, but it won't start. Is this likely a problem with the start button, or the motor? The belt is fine.
It's not the start button if it responds to the button. Make sure the motor spins freely. If so, make sure you have voltage going to the motor. If so, check the start capacitor (if equipped) Good luck.
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 • Dryers
Belt is broken on my Magtag Neptune Dryer #MDE3000AYW. How do I take the front panel off to get to the belt?
Hello del4221,
Here is a link to your dryers assembly drawings and parts lists. http://www.pcappliancerepair.com/model-display.php
You should be able to see how it is assembled and be able to disassemble it with this documentation.
Hope this helps..
Regards
Rick
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
