Question about The Computers & Internet
Connecting a Card reader to the motherboard - The Computers & Internet
Posted by Graham Neil on
  • Larry Ng
    Larry Ng Jul 02, 2020
    what motherboard, in what PC?
    what card-reader is it? SD ,microSD, security card, or?
    tell what PC and show link to cardreader being sold or show photos of yours. so we can see it.
    or tell make and models of all above.
  • Anonymous Jul 05, 2020
    example
    i have X Pc, i went and bought a Z card reader, Z
    it is SD card reader with adapter kit and is USB reader, I have X PC with Windows 10
    and w10 does not like my 10 year old usb reader.
    nothing new there W10 fails to operate vast things USB 10,000 of things older than 10 years old. are now DEAD and web cams and MORE lots more.
    X = a dell XP8900 PC.
    OS is w10
    reader is old. very very old.
    answer 2, lets say you have dell desktop
    and was bought without dells card reader
    and you need to buy one to plug it into the custom dell reader pins on unstated motherboard. only sold used on EBAY dell does not sell old readers.
    or
    why not tell exactly what you want to read
    tell that first. exactly what is this card deal... SD (uSD) or express security card or?
    and what OS you run.
    then answers can be possible.
    helpers can not work with you blind in a text box.
    no PC told
    no OS told
    no reader told or kind of card.
Zoom-The Computer Guy
    Top Expert:
  • The Master
  • 2,000 Answers
Posted on Jul 16, 2020
JonSnell Electronic
    Top Expert:
  • The Master
  • 31,776 Answers
Follow the installation instructions.
Posted on Jul 01, 2020
Everything was disconnected from my motherboard and power supply. It is an Asus K8V-MX/s
You will get all the required stuff as i have viewed and confirmed, from this source.
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
best of luck!
Mar 11, 2012 | ASUS K8V-MX Motherboard
Is there a way to attach mutimedia card reader to gateway micro atx motherboard
I'm not sure which model number you have, but you are able and have USB ports on your computer, then the answer is yes. You can do it two ways: One way (simplest way) is to buy an external multi-reader that plugs into a USB port. The second (More permanent), is when you open up your case and look at your motherboard, you should see a white cable that is connecting to your front-mounted USB ports. Follow it back to the motherboard and see if you have another slot to put another cable in for you multi-reader (and make sure you have a spot available in the front of your case to put the multi-reader). If you don't have a spot, or another plug, then go to newegg.com and buy an internal reader with at least one or two USB ports, and replace your existing front USB port.
Mar 12, 2010 | Gateway (Sound/VideoOn) ATX Motherboard...
Connecting a card reader to the mB
Most multi card readers are usb, but not the external kind that fits in the back of the motherboard, the internal kind.
If you look at the edges of the otherboard you will see three small blue connectors. Those are internal USB connectors, it should say next to them. Plug it in the correct way round (it will only go in one way) into any one of the three.
Dec 02, 2009 | ASUS P4PE/L (ASU49J) Motherboard
Where do i plug a card reader into my pcchips a33g
Most card readers are driven by USB ports. The card reader connector should match the pins of one of the USB connectors on the MB.
Nov 20, 2009 | PC Chips A33G (V1.0) Motherboard
Disk in h is not formatted
As I understand, you inserted a disk in a card reader and you were connecting the card reader into your computer, is it right? If yes, then the problem could be the disk or the card reader.
* First, try connecting the card reader into different USB port.
* Try connecting it in a different computer just to isolate the problem.
* If the problem is isolated to the disk and card reader, try inserting another disk just to make sure that the card reader is working and plug it in to the computer.
* If another disk works with the problem card reader, then buy a new disk. But if same problem occurs though you use another disk, try another card reader.
Doing these steps would let you know which is causing the problem.
Have a great day!
Oct 18, 2009 | Rio Tablets & eReaders
WLAN & CARD READER CONNECTION.
http://www.ehow.com/how_2153205_install-internal-card-reader.html
if its just a plane ...universal reader ...( no antena needed )
http://www.ehow.com/how_2151954_install-internal-card-reader.html
http://www.youtube.com/watch?v=kgyXW5rs3Ek
May 19, 2009 | Computers & Internet
SD MEMORY CARD!!!!
Hi Sandra,
If you are attempting to transfer photos off an SD card in your camera and you are connecting your camera directly to your PC then you may want to get an external SD card reader as this is a fairly common problem and an external reader should solve it.
If you are already using a card reader I would think that the cables connecting the reader to your computer are defective. To test this try connecting your card reader to a different USB port, if it functions fine then you know the problem is with the previous port you were connecting too.
ALSO, check in "my computer" and see if it registers as a removable drive there. If not, then check in the device manager while the card is inserted and look for any yellow icons. There is a chance that the card reader need a driver installed or updated.
Hope this helps and please take a second to rate!
Mar 20, 2009 | Acer Aspire™ T180 PC Desktop
Installing a card reader
On my E210882 motherboard in an Emachine T2824, the card reader is plugged into J9F2 connector on the motherboard.
Aug 29, 2008 | Dell (E210882) Motherboard
Card reader connector
Open you're manual for the PC. Find an opened USB port & plug you're card reader on the pins. Match the pins with the card reader connector. Card readers can & do use different connectors. (USB, PCI & SATA). If you list the name & model of you're card reader, I can be more specific.
You should have received a small quick guide with the card reader.
Jun 14, 2008 | Computers & Internet
Can not read SD card, game pad
You need to install your camera's drivers from the disk that came with it.
Unplug your camera from the computer >> insert the camera's driver CD >> install drivers >> restart the computer >> connect your camera via USB >> a windows pop up will let you know that it has found a new device. If you don't see the pop up this means your USB port is malfunctioning and it's normally from a malfunctionnig motherboard.
If you want to connect it through your card reader I'm affraid you need to buy a new card reader that supports 2G SD card. your current card reader does not supports 2G cards.
Kind Regards
Parkook
Oct 26, 2007 | Acer Aspire 5002WLMi Notebook
Computers & Internet Logo
49 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
