Question about Freezers
An eco defy chest freezer needs compete wiring diagram from thermostat , switch to see why it's tripping the supply after repairs was done.
Posted by Heiman on
Vernon Taylor
  • Freezers Master
  • 7,139 Answers
Defy 130L chest freezer wiring diagram
Do a google search for a wiring diagram for your model
Nov 05, 2017 | Freezers
Holiday chest freezer lcm070lc
There are only three wires, aren't there? One is a safety earth, probably green or green and yellow. It goes on the spade attached to the metal of the thermostat body. The other two are a live and switched live. They go on the two spades that come out the plastic body. If there happens to be a third, it will be an alarm signal wire. Connect in any order you like. If the compressor comes on and the signal light, all is well. If the signal light does not come on, and the compressor switches off at -12c swap 2 of them. If none of this happens, switch 2 of them.
Apr 21, 2014 | GE Freezers
Defy f640 wiring diagram
Defy F640 freezer fan keeps switching on and off and does not cool.
Jan 19, 2014 | Freezers
Need diagram for thermostat for chest freezer
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire. HERE
If you have questions please let me know, Thanks Sea Breeze
Mar 08, 2013 | Frigidaire 15 cu. ft. / 425 liter Chest...
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Will not freeze
Possible bad thermostat. You can disconnect the thermostat, take a jumper wire and plug in where the thermostat goes. This will tell the unit that the unit is turned on. If the freezer freezes, then it is the thermostat and it needs to be replaced. They can be purchased from an appliance supply house. Do not run the unit with the jumper wire or the compressor will run and not shut off.
Nov 15, 2009 | Zanussi 11 cu. ft. / 311 liter Chest...
Wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Jul 10, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
