SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
SOURCE: kenmore sxs-freezer ok, fridge side not cooling below 50
Hi Thanks For The Question. Did You Check The Back Coils For A Dirty Condenser Or A Bad Fan At The Back Check That Thanks The Appliance Doc
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
SOURCE: Ice build-up in lower freezer. We replaces the
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check , defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control. Part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2756GEW&productCategoryId=0165000&brandId=3048&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00002&componentDescription=CONTROLS&documentId=M0404275&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Sharp SJ-42-WH self-defrosting fridge. Freezer
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
