Question about Health & Beauty
How do I get my weight watcher scal e to stop showing "ron"?
Posted by Brenda Leichtnam on
5 Related Answers
Anonymous
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
Anonymous
  • 59 Answers
SOURCE: My weight watchers scale reads ron when you tap it.
I would contact customer support here is the webpage on the site.
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
Anonymous
  • 59 Answers
SOURCE: GETTING ERROR "ron"
If we are talking about a conair weight watrchers sclae i contacted manufacturer as this is quite the little eppidemic I have 3 of you with same problem. here is the response unfortunately i had contacted the canada location and not the us so i will provide the contact info for the us after the response. The unti is under a 10 year warrenty and usually warrenties are void if you mess with the unit so I highly reccomend you contact them first.:
Thank you for your email.
Simply mail us your defective product or part with a detailed letter stating your name,mailing address, model , serial number, a brief description of the problem , a photocopy of your receipt and a cheque made out to Conair Canada for Conair products($5.00) or Cuisinart Canada for Cuisinart products ($10.00) for return shipping. Your product will be serviced and or inspected for possible warranty repair or replacement.
Please note that all replacements will take from 3-6 weeks and will not be replaced immediately. They must go through are technical department for testing.
Please also be advised that we do not have a reimbursement or refund policy.
CONAIR/CUISINART CONSUMER PRODUCTS
100 Conair Pkwy
Woodbridge ON
L4H 0L2
Tel: 1-800-472-7606
Sorry for any inconvenience this may cause.
Regards,
Consumer Service Representative-CP
Conair Corporation
Service Department
150 Milford Road
East Windsor, NJ 08520
Conair Corporation
Service Department
7475 N. Glen Harbor Blvd.
Glendale, AZ 85307
1-800-326-6247
www.conair.com
and your warrenty if for 10years sorry for confusion
Conair will repair or replace, at our option, your appliance free of charge for
120 months from the date of purchase if the appliance is defective in
workmanship or materials.
To obtain service under this warranty, return the defective product to the service
center nearest you, together with your sales slip and $5.00 for postage and
handling. California residents need only provide proof of purchase and should call
1-800-3-CONAIR for shipping instructions. In the absence of a receipt, the
warranty period shall be 120 months from the date of manufacture.
ANY IMPLIED WARRANTIES, OBLIGATIONS, OR LIABILITIES, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTY OF MERCHANTABILITY
AND FITNESS FOR
A PARTICULAR PURPOSE, SHALL BE LIMITED IN DURATION TO THE 120 MONTH
DURATION OF THIS WARRANTY. Some states do not allow limitations on how long
an implied warranty lasts, so the above limitations may not apply to you.
IN NO EVENT SHALL CONAIR BE LIABLE FOR ANY SPECIAL, INCIDENTAL, OR
CONSEQUENTIAL DAMAGES FOR BREACH OF THIS OR ANY OTHER WARRANTY,
EXPRESS OR IMPLIED, WHATSOEVER. Some states do not allow the exclusion or
limitation of special, incidental, or consequential damages, so the above limitation
may not apply to you. This warranty gives you specific legal rights, and you may
also have other rights which vary from state to state.
Posted on Apr 17, 2009
Anonymous
SOURCE: Weight Watchers scale WW11D
I have the same problem
Posted on Oct 13, 2009
Anonymous
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
Posted on Mar 22, 2010
How do I reset my Weight Watchers Scale WW37GD?
To Set:
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh:
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Nov 13, 2017 | Weight Watchers Health & Beauty
Our Weight Watchers scales have suddenly stopped giving us a correct weight - both my husband and myself are showing weights of 6st.5lbs and we are very much heavier than that - can you solve the problem? ...
It ispossible that the LOAD CELLS are damaged or there is a fault in the mechanism that is jammed and not reacting to the weight loaded on the tray. So remove and check if this is free and the depression is noticable. If so the LOAD CELL must be replaced.-- hoping that the main control board- processor is OK.
Sep 22, 2011 | Conair Weight Watchers WW-87 Body Fat...
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 | Vacuums
Same problem
be sure you are barefooted when weighing yourself, won't work with anything on your feet.
Oct 13, 2009 | Conair Weight Watchers WW-87 Body Fat...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate it?
From main menu: go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop/exit key to complete the prcess.
Jul 16, 2009 | Porter Cable Measuring Tools & Sensors
Do you know how to calibrate the scale?
Jun 25, 2009 | Robinair Cool Tech 34700Z Recovery,...
Health & Beauty Logo
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
