Question about LG Televison & Video
I have a 60 inch lg plasma model number in photo. It turns on but the screen is real dim what should I do
Posted by Dustin Burton on
    Top Expert:
  • LG Master
  • 76,407 Answers
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on Jul 01, 2020
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
phil_frye
Philip Frye
  • 295 Answers
SOURCE: The screen on my 4 yr old 42 inch LG plasma keeps
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: trying to connect to LG
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Posted on Dec 26, 2009
Chi Chu
  • 8457 Answers
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Posted on Mar 10, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: i have a 60 inch LG Plasma tv and the base stand need screws need to know what size screws
See a lot of this kind of problem: easiest way is with the model number call the LG customer service number and get the bolt info for number and thread type---IN ALMOST EVERY CASE THE BOLTS WILL BE STANDARD FINE THREAD AND AVAILABLE AT MOST PLACES LIKE HOME DEPOT.
Posted on Apr 16, 2012
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
I have an LG 60 inch plasma model 60PV450 that has no picture but does have sound
It is probably the backlight inverter board. These are common problems on all LCD and Plasma units that use fluorescent backlighting.
Jan 20, 2015 | LG 60 60PV450 Plasma TV
L have a lg plasma 60 inch tv but the sreen its creaked
There is no other way than replacing the screen.
Mar 14, 2013 | LG 60PS80 Plasma TV
Lg 60 replacement screen
there is a bar code label on the inside on the panel--be careful as we have to photo that and have LG id the part and the display panel has to be the exact one---cost of a new one more than a new set.....
Oct 17, 2012 | LG 60 60PV450 Plasma TV
Can my 60 inch lg lasma be fixed
Yes,what wrong with ur 60" LG Plasma tv,but not if ur screen panel is broken or damage,because replacing the screen panel it cost the same as a new tv,might even more after the labors.The screen panel's are 90% of the tv that why.It also limited producced by the tv industries.
Apr 30, 2010 | LG 50PX4DR 50 in. Plasma TV
Open Questions:
Televison & Video Logo
42 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
