Question about The Office Equipment & Supplies
Re:Coolscan LS 8000 of the connections to the front panel wire bundle, the D3C Switch Detector needs replacement. Which model 1220, 2220, 1210 or 2210 is correct? Is there an instal protocol?
Posted by kuken on
Tom Chichester
    Top Expert:
  • The Master
  • 56,036 Answers
Contact Coolscan directly to inquire.
Posted on Jul 05, 2020
5 Related Answers
sigma_shiva1
SHIVAJI YADAV
  • 188 Answers
SOURCE: front panel hook up
HEY MAN U HAVE SERIUS PROBLEM... OK THIS MAY SOLVVE U R PROBLEM....JUST DOWNLOAD U R MOTHERBOARD USERS MANUAL...AL CONNECTIONS ARE GIVEN THERE..EVEN FRONT PANAL SETTINGS TOO.... BEST REGARDS MAIL ADD- [email protected]
Posted on Oct 10, 2007
Anonymous
SOURCE: Nikon Coolscan 8000 ED Film Scanner
Jim try looking into the vuescan software.  It comes highly recommended and is priced very reasonably.
Hope this helps, Rose
Posted on Dec 17, 2007
Anonymous
  • 472 Answers
SOURCE: My ASUS P4T533-C Manual is
This is the bit your after I believe...
Posted on Apr 18, 2008
Anonymous
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
Anonymous
  • 20 Answers
SOURCE: I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Posted on Dec 16, 2009
Testimonial: "Thanks for prompt and clarifying answer!"
Nikon super coolscan 8000 ed driver for windows 7
quite likely you will never find any win 7 and 8 do not support much of our old hardware tho it still functions with older versions of windows that ar no longer supported .
Sep 05, 2014 | Nikon Super Coolscan 8000 ED Film Scanner
Error code LS
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Mar 26, 2014 | Precor Exercise & Fitness
Repairman says it is getting no power. The circuit is fine. Could the box inside the dishwasher need to be replaced. He said he isn't an electrician.
Sometimes the wire nuts come loose inside the connection box due to vibration. I have
also seen them burn through (when aluminum wire is connected to the dishwasher).
The power to the circuit should be shut off at the breaker panel and checked with
a "Non Contact voltage detector" before removing cover to inspect wire connections
in the connection box. The non contact detector is sold at many big box home
improvement stores for around 12 dollars. I recommend it since many breakers are not
marked at the panel or incorrectly marked, and the wiring can contact the chassis if
the wire nuts are burnt through. Check the detector at a working outlet prior to using.
Hope this helps.
May 28, 2011 | KitchenAid Dishwashers
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Trying to replace Intermatic with Utilitech inwall timers. Have 2 black wires in wall box with other switches for other lights. Which of the Utilitech 4 wires- black, red, white & green get conected to...
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Apr 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
Oct 29, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Firewire. USB2
Either or is my understanding- the scanner will accept either. I can see no need for both.
Sep 01, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon coolscan 9000
Close the scan program --turn off and unplug the scanner---plug the LS9000 back in and turn it on----reopen the scan program--this is my method on my LS-8000--It does this quite often !
Aug 30, 2007 | Nikon LS-9000 Film Scanner
46 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
