Question about Garden
Line is constantly breaking on my 20V B&D trimmer. Have tried 2 new spools with no luck.
Posted by Bill Pennington on
Vernon Taylor
  • Garden Master
  • 6,659 Answers
Strimmer line is consumed constantly in use either by wear against abrasive surfaces or being snagged against stems and suchlike it can't cut through and so tends to break. With lots of patience a lot of those stems can eventually be cut.
Early strimmer users became fed up with the process of stopping work, upturning the machine and releasing more line and starting over and so in order to maintain sales the bump and automatic feed heads were developed.
You description suggests you are using your low powered grass trimmer for heavier work than it is designed for.
Posted on Jun 30, 2020
Replace line
Two possibilities:
1. Buy a new spool. Make sure you bring your make and model/size to the store to get the correct replacement spool, or
2. Buy new line and manually wind it into the existing spool. Smaller lawn trimmers and edgers use smaller diameter line than larger lawn trimmers and edgers.
Good luck.
Paul
May 31, 2015 | Garden
Bought new Ryobi P2002P from local home improvement chain, less than 2 wks ago; after assembly and charging battery, I found the .065 string equipped with the string trimmer kept breaking when trying to...
My first choice for a repair is to return this unit to the store, so that they will know that what they are selling is not working.
My second choice is to have you put a good quality line on this trimmer. Ryobi has tried to save a few cents by using a very lightweight line. I have not had a lot of personal experience with battery operated trimmers, but my impression is that they are very light-weight and take significantly more time and effort to achieve the same result as their electric or gasoline counterparts.
Check your owners manual to see if you can use a size .080" trimmer line. Stay with round line. The square or star shaped lines tend to stick to themselves and don't feed well. If you have to stay with the .065" line, find your local lawnmower repair shop and see if they sell a higher quality line.
Good luck.
Oct 21, 2010 | Garden
Black&decker GH 1000 trimmer. The line breaks when spool is full
Try using a thicker line when using the thinner line it is good only for grass if you should hit fence or concrete it will eat it up and you will be pulling it out every 5 minites or less.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
I need to put in new string -- don't know how to install. I need to know what to remove -- do I unscrew something, or do I just stick the string inside the casing?
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
Nov 04, 2009 | Black & Decker 14" Grass Hog Xp...
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
