Question about LG Televison & Video
I have an LG 32" 7 yr. old tv that had colored vertical lines and sound. Finally it turned to solid black.
Posted by sheri 0 on
    Top Expert:
  • LG Master
  • 76,407 Answers
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent...
Posted on Jul 01, 2020
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
A red vertical line that doesn't go away. Is it a tube or what. TV is about 3 yr. old.
A LCD does not have any tubes in it and the red vertical line is a driver in the TV that has gone bad.
Jul 22, 2011 | Emerson LC320EM8 32 in. LCD TV
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Good luck and take care in handling it ........
Jul 07, 2010 | Envision L32W761 32 in. LCD TV
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Nov 11, 2006 | Philips 32PT5441/37 32" TV
Open Questions:
Televison & Video Logo
70 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
