Question about Refrigerators
I have the freezer turned up to -5 and the ice cream is still soft. What do I do? model wrx9865slhvoo bottom mount refrigerator
Posted by Irene Fabio on
Andrew Serna
    New Friend:
  • 41 Answers
When you turn the freezer to the highest setting you block the air vent going to the fridge keeping the colder in the freezer
Try turning the fridge up
Clean underneath vacuum
Set a good thermometer inside the freezer and check temp 0 to ,5f
How long is this been the issue?
If you have an ice maker the production might slow/low as well
Also real cream won't freeze very well
Any control change allow 24hrs
Posted on Jul 01, 2020
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 32,974 Answers
First thing is to vacuum all the fluff off the condenser coils. always a problem with air flow and high ambient temperatures in the summer. I did mine last week.
Soft ice cream is the best :>) Check the temperature inside the cabinet with a thermometer.
And finally, it that is minus 5 Fahrenheit, it may be too cool. If it is minus 5 on a dial where Zero is the median and there is a plus five as well, the PLUS side makes it colder.
click COMMENT under my post if you need further help. I am a retired chef - caterer with 50 years using refrigeration ??
Posted on Jun 30, 2020
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
We purchased the fridge in Jan a '11, today the freezer was not as cold as it should have been to the point the ice cream was soft. According to the manual, I increased the temp from 4 to 5. Since then...
The fan should run cotinously until either the temperature is satisfied or the unit goes into defrost.
Changing from 4 to 5 is not a way to determine the temperature, rather you should use a good thermometer. Look for 0*F.-5*F.
Mar 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
