Question about Electrical Supplies
What output is the generator would it run our motorhome
Posted by Graham booth on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Electrical S... Master
  • 35,785 Answers
Output depends on what loads you draw on any genset
Posted on Jun 30, 2020
My motorhome generator keeps sputtering and dying.
Check the fuel system e.g.the filter the hose and tap, also the on of elec. switch.
Sep 16, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
No power to coach when generator runs but power
Do you have automatic switch over in your system, or is there a receptacle where power cord stores, that you need to plug power cord into, for power from generator?
Oct 13, 2009 | 2002 Ford E350
Genarator runs short period of time & shut down
Hi!
We can help. Check out our help centre to diagnoses the problem. https://www.generatorguru.com/need-help/
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
www.GeneratorGuru.com
Jul 20, 2009 | Electrical Supplies
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
May 20, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
