Question about Roland Audio Players & Recorders
I have a Roland VS-2480.The problem is there is no sound out put.
Posted by vedfilms on
Terry
  • Roland Master
  • 11,347 Answers
I have a roland vs 2480 workstation. i turned it on a while ago and it is not loading a project. can someone help?
Most of those units needed a new cdr drive, which means it's possible that the current material could be lost. Inner Sound is a Roland authorized facility, you can call them.
Nov 18, 2014 | Audio Players & Recorders
How to connect Roland MV-8800 fiber optic to Roland Vs 2480HD
I'm sorry. I have no first hand experience with these units, not to mention, I'm a hardware guy. I can repair it, but I have to look in the owner's manual, just like you, to use it. These are questions you should be able to find in your owner's manual. If not there, check with the Roland website.
Jul 05, 2014 | Roland Mv-8000 Sampling/Record Production...
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
Problem getting VS-2480 to connect to internal drive. also to external drive sometimes it works sometimes it won`t Need service manual for mounting new harddrive internally SATA 160 GB Experienced...
Hi Karl,
First of all, thank you for purchasing the copy of Roland VS-2480 Service Manual.
Please email me at [email protected], I will send you the copy.
May you and your family have "Prosperous New Year 2012"!
Again, thank you so much!
Mjsazon
Dec 29, 2011 | Roland Vs2400CD Digital Workstation W/CD...
Roland VS 2480 v2 - working on album and received error message "load project please wait" since last night. have tried turning machine off and on and unplugging it. still same message.
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
Dec 12, 2010 | Roland Vs2400CD Digital Workstation W/CD...
When I turn on my roland vs 2480 it never makes it past the load project start up screen. What can I do? please help
moz-screenshot.pngHave you tried to do a factory reset?
Dec 03, 2010 | Roland Vs2400CD Digital Workstation W/CD...
I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
Jun 04, 2008 | Roland Vs-2000CD Digital Studio...
Roland VS 2480
Press the "UTILITY" button under the Menu heading above the 10 digit key-pad. Under "System Parameter" -Param3, check that PS2 Mouse is set to "ON" and (of course) that the connector is firmly inserted into the mouse connector socket.
May 13, 2008 | Audio Players & Recorders
Roland VS-2480 DVD Workstation
have problem with vs 2480 anyone fixes  roland vs  2480
Apr 10, 2008 | Audio Players & Recorders
Roland VS2000CD
Shelly, I have a 2480 but it must be very similar. Import the drum track as a wav file into two of your tracks within the same project. You must make sure the file is a WAV file and nothing else.
Hope it works, on the 2400, I am sure it must since it is a must have.
Mike
Dec 16, 2007 | Roland Vs-2000CD Digital Studio...
18 people viewed this question
Top Roland Audio Players & Recorders Experts
Ekse
Eric Rotmil
Eric Rotmil
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
