Question about Belling Microwave Ovens
Hi, can I use rubber legs intended for things like laptopns with self-adhesive to replace the missing leg on a Belling SJ17SS microwave oven? Thanks.
Posted by Geen on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,529 Answers
Sure can and why not.
Posted on Jun 30, 2020
Where can I get hold of a Belling BEL GT17SS microwave foot?
Temporarily, you can use a wine-bottle cork, cut to size. Mind your fingers!
Feb 13, 2015 | Belling Microwave Ovens
Convection/microwave turntable motor arcing; 7 yrs old is it worth fixing
If arcing and is seven years old time to replace the item, more cost effective with full warranty.
Mar 05, 2012 | Microwave Ovens
I AM GETTING ELECTRICITY TO THE 220 PLUG AND THROUGH THE 220 PLUG WIRE TO THE STOVE JUNCTION BOX. THE STOVE TOP AND OVEN HEATING ELEMENTS ARE NOT HEATING UP BUT THE INDICATOR LIGHTS FOR BOTH ELEMENTS SHOW...
The indicator lights operate on 120 volts whereas the elements operate on 220 volts.
Using an electrical test meter go between the two hot legs and see if you are getting 220 volts. If not you have an open or non completed circuit.
Do not test from one leg to ground as you will probably read 120 volts for each leg. By reading across both legs you should get 220 volts.
May 03, 2011 | Microwave Ovens
A tree limd fell on a power line running across my yard to his house. now we only have partial electricity.any ideas why?
Hello elle..... Definitely call the power company right away. You have probably lost one leg of your power so that instead of having two 110 volt legs going into your electrical panel you have only one leg. That would eliminate half of your power.
This is a potentially dangerous situation so please call the power company right away. ALSO do not use your electric dryer or electric stove/oven under any circumstances at these require 220 volts and using them could damage your appliances. Joe
Thanks for choosing Fixya!
Feb 02, 2011 | Hotpoint RVM1435 Microwave Oven
MANUAL FOR BELLING MICROWAVE
There are so many models.
The link would be :-
http://diplofix.com/forum/manual%20for%20belling%20microwave
Put the model number and download.
If not available, let me know.
Thanks.
Jun 18, 2009 | Microwave Ovens
Turntable motor or support/coupler failure.
Isn't that actually an R1461A?
When you try to turn it by hand (as in the video) do you hear the motor whine? Is there resistance? Or does it just turn freely?
The hole in the turntable support should either be round with a flat side or a cross shape. If that's damaged, it won't work.
In some cases, the legs of the support get too hot and when the weight (food) is removed, they bend downward in relation to the hub.
I have solved this problem in the past by carefully heating the area where the legs meet the hub, using a gas stove flame or a torch.
Then I place it on a flat surface, weighted down so as to hold the legs so they will cool in the correct position.
If you have to do it more than once, the support should be replaced.
You can see if the motor is turning by removing the support and placing something wooden or plastic into the hole and see if it turns when you cook.
If you replace the support or motor, you should also replace the "packing" which is a rubber grommet.
You can find an exploded view here, and the parts list is here, but the best place to order Sharp parts is Tritronics.
To replace the motor, you need to remove the bottom panel of the oven, then remove the motor screws.
Sep 28, 2008 | Sharp R-1460 Microwave Oven
Delonghi microwave/convection, central wheel cog where glass turntable cogs go is lower than outside wheels so turntable does not turn
In some case, the legs of the support get too hot and when the weight is removed they bend downward in relation to the hub.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Microwave Ovens
Kenmore microwave uneven base
It seems that when you bought the microwave the metal or plastic on the bottom of the unit is bent or warped. If I were you I would return it because yo cant really fix it
Dec 29, 2007 | Kenmore 63263 Microwave Oven
Will i need a separate 110 circuit????? cannot use the 220v leg??
I would contact a few electricians for their opinions. Appliances like microwaves and ranges, etc. should be on separate circuits / breakers due to the high currents they draw.
Dec 08, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
STEVE yes that one
ray gallant
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
