Question about Air Tools & Compressors
Finish pro 10 the driver don't return all the way for the next pin nail
Posted by Dean Becher on
Terry
  • 11,346 Answers
Call toll free telephone number or email manufacturer for assistance. Contact information in free online pamphlet:
https://www.senco.com/docs/retired-manuals-and-parts-charts/FinishPro10_PC.pdf
Posted on Jun 30, 2020
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
The nails don't advance to the fireing pin
Assuming that the nails are moving ok down the rails and the pusher is in good order, if the driver does not return to the top position, the nails will not move into position. Remove air line to gun. Use metal rod to push driver to top position and verify that nails move into position. If the driver was at the top position, check for debris in rails or wrong nails. Place a strip of nails on the outside of the rails and align the nail heads with the rails. The first nail should align with the path of the driver. If the first nail head is tilted back away from the path of the driver, the driver will just push nails back into the rails and slip past. If nails are correct and driver does not return to top, suspect worn piston oring or cracked lower bumper or lack of lubrication.
Aug 24, 2011 | Stanley Bostitch N80s Nailer -rebuild...
Only shoots out one nail for every 4 or 5 trigger pulls
The gun will miss fire if the driver does not return to top position allowing nails to move into position. Could be bent driver, faulty trigger, cracked lower bumper or check valve not in place. Easy to check if trigger. Remove air supply, and remove the pin holding the trigger. Fire the nailer by depressing the firing pin with your finger. If the gun works ok, single fire trigger is faulty or safety foot is out of adjustment. If still miss fire, remove head and pull out cylinder and piston. Check for bent driver, cracked lower bumper or black band (check valve) is out of place on outer part of cylinder covering a row of holes.
Aug 23, 2011 | Porter Cable Cable Factory Reconditioned...
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
Drive pin will not retract
Return spring is week and the chamber may need more lubrication.
Oct 07, 2009 | Craftsman Nailer Kit, Palm Air Driver
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Jul 30, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
23 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
