Question about Sewing Machines
I am new and I want to start the machine, but I do not know if the threading is correct. I also need an instruction manual please. Regards Alba
Posted by albaswart on
Deana Pearson
    Problem Solver:
  • 5 Answers
Most machines thread similar. Across , down , through tensioner and then through the arm , then down to needle.
You can start it threaded or not and most manuals are available online if you Google machine make and model
Posted on Jul 02, 2020
ray gallant
    Top Expert:
  • Sewing Machines Master
  • 68,282 Answers
AS WE DO NOT KNOW THE MAKE WE CAN NOT ASSIST YOU .
Posted on Jun 30, 2020
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Janome New Home sewing machine instruction manuals
Make It Handmade Threading Your Serger or Overlocker
Nov 25, 2016 | New Home Sewing Machines
How do I get my Serger to sew properly?
I'm afraid you've threaded your serger incorrectly. I've done it myself more than once, so I try to make sure that I tie new thread to old and pull it through the machine rather than try to re-thread it. That avoids the problem for the future, but doesn't help you now.
Here's what you can do right now to work out the problem:
1. Get out your owner's manual and check the thread path(s) for each thread. Be sure you've got them right, especially the loopers (usually the two threads on the right-hand as you look at the machine).
2. If you don't find any obvious errors, change the sequence of the looper threads - that is, which one is threaded first. I know it doesn't sound like this will help, but it fixed mine.
3. Be sure that none of the threads are caught under the feed dogs, they should pull fairly freely toward the back of the machine.
4. Start sewing without fabric in the machine. I know this is wrong for a standard sewing machine, but you should get a 'chain' with a serger. If it's not 'chaining,' go back and try these steps again.
5. If that doesn't fix the problem, or if it chains and still won't stitch, change your needles. They should be changed now and then anyway.
6. Be sure to lubricate your machine often according to the owner's manual. Most sewing machines need more oil than they get.
Apr 08, 2015 | Sewing Machines
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
I need to know how to set the tension. I need to know how to thread the bobbin. I need to know if the needle makes a difference. My stitches are loose and sloppy. They should be interlocking between...
Would be helpful to know what model machine you have.
A new machine should not need tension adjustment, so guessing it is not being threaded correctly. There should be adequate instruction on how to do this and how to wind a bobbin in the manual.
The main thing is you need to have the presser foot UP when you thread the top thread. This opens the tension discs so the thread will go between the discs and be put under tension once the presser foot goes down before you sew. When you thread the bobbin, be sure it is unspooling in the correct direction and that it clicks into its tension slot. A Universal 80 needle will do for 95% of what you sew, exceptions being very lightweight fabric, knitted fabrics, or very heavyweight fabric.
Write a reply back to Fixya if this does not help you, but include more detail on just exactly which machine you have.
Jan 13, 2011 | Husqvarna Viking 1
Thread keeps breaking and needle breaks
hi there
1- change needle with new one and try sewing.
2- make sure your machine threading correct.
if you can use instruction or service manual send me your email i will send it by email to you.
best regards
ashraf abozid
[email protected]
Sep 21, 2010 | Juki DNU-1541 Mechanical Sewing Machine
Thread Breaks
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
Jul 25, 2009 | Brother LS-1217 Mechanical Sewing Machine
How do I thread my Singer 7422?
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading.
Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
Jun 22, 2009 | Singer 7422
Threading my bobbin and correct tension
If you go to this link, it shows for the 117.591 model, but it is threaded the same exact way as the 117.959, that will thread the machine and bobbin, I have used this to thread my machine which is the 117.959, and it sewed perfectly until I started messing with the tension, I still haven't figured that part out yet, but I will and when I do, I will let you know. You should be able to thread the bobbin correctly with the manual, if you are pulling the bobbin through the hole the needle is going down in, your bobbin is threaded correctly, if the problem is like mine, your not making stitches, the problem is with the tension. I hope I have helped and if not, sorry.
http://sewusa.com/Threading_Diagrams/Threading_Pages/Kenmore_Sewing_Machine_Threading/kenmore_117591_threading_diagram.htm
Jan 27, 2008 | Sewing Machines
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
