Question about Samsung Televison & Video
I have a Samsung HL-T5689S DLP TV that has developed a black bar across the bottom portion of the screen. Rest of picture normal. Is this an indication of a failed dlp chip?
Posted by Edward Camuffo on
    Top Expert:
  • Samsung Master
  • 76,390 Answers
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on Jul 01, 2020
5 Related Answers
Anonymous
SOURCE: Samsung HL-T6176 DLP How to Adjust (center) the picture
I would love to tell you how I fixed the above issue and if you would like to subscribe to my site I will tell ya.
Posted on Mar 13, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
Anonymous
  • 505 Answers
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Posted on Jan 08, 2009
John
  • 26 Answers
SOURCE: HL R5087W DLP
try reseating the dvi cable inside the set
Posted on Jun 13, 2009
Anonymous
  • 6 Answers
SOURCE: Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Posted on Aug 20, 2009
My dlp hl-s4266w had developed a 10 " wide vertical darker area than the rest of the sceen
Usually this will be on top or either side and the problem is the optical light engine is damaged from heat----seen about a dozen.
Dec 04, 2012 | Samsung HL-S4266W 42" HDTV
I have a Samsung HL-N4647W 42 inch HDTV DLP TV and the screen is blurry and out of focus with a black curved block across the bottom. what can I do to fix it?
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
HL R5087W DLP
Jun 13, 2009 | Samsung HL-S5087W DLP TV
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
SAMSUNG HD DLP HLN5065 50" TV
The problem of your DLP TV is a defected color wheel,replaced that so it will works normal again.
Hope it may help you;
Regards,
VOTIT
Sep 22, 2008 | Samsung DLP HL-P5663W 56" TV
Color
heard a crack & black and white picture is ok please check chroma ic & its related parts of chroma portion of that IC
Sep 23, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
