Question about Canon Office Equipment & Supplies
My i9900 canon has gone spontaneously from working fine to stubbornly "offline". I decided just to delete and reinstall it, but can't find the CD or its equivalent online. Any help please?
Posted by Dan Guire on
  • Canon Master
  • 6,114 Answers
What OS do you have? Please add the update version for Windows 10. The drivers are still available from Canon here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/i-series/i9900?tab=drivers_downloads for supported OS versions. It looks like the printer used Windows Update for to install most of the drivers under Windows 7. There is an optional update for the driver on the site but it doesn't work unless Windows Update installed the basic driver. The Canon didn't officially support the printer for any OS after Windows 7.
The Windows 7 driver worked under 8 (8.1) and some versions of Windows 10 for a while. (Under Windows 8, the ZoomBrowser software didn't work.) Then Microsoft became strict about not allowing unsigned drivers to install. The easiest solution is to find an old Windows 7 computer to connect to the printer. Alternatively, get an unused install license and build a virtual machine to connect to the printer. Note: recent cumulative updates for Windows 10 have caused issues with USB printers.
If you are using Windows 8 or 8.1, try connecting the printer via the USB port with the machine off. The restart the computer; make sure that the Windows Update is set to find updates for other devices (not just Windows). If you are using the printer over a network, some found using the Canon ProMark 9000 series drivers worked.
I hope these ideas help. I wish that I had better news for you about Canon support.
(Building a virtual machine OS depends on your CPU allowing virtualization and free memory. You also need the Windows Pro or Enterprise versions of the OS for Hyper-V (Windows 10) or the Windows 8 VM equivalent. Third-party tools for creating a virtual machine may work on the home edition.)
Posted on Jun 29, 2020
My canon i9900 is offline
It usually means that the printer is off, not connected to your computer or your computer does not recognize it. If your computer doesn't recognize your printer, go to control panel and click on add new hardware, then follow the directions . After trying all the above try using your printer once again.
Mar 18, 2012 | Canon i9900 InkJet Photo Printer
Canon i9900 won't install on new win 7 machine downloaded driver off canon support site
Install the driver from canon website the driver that works for i9900(win 7 64bit ...what ever you have), reboot
go to device manager, highlight the i9900 and goto update driver. and it works! at least for me.
Dec 17, 2010 | Canon i9900 InkJet Photo Printer
Windows 7 no longer recognizes my Canon i9900 printer. I have tried uninstalling and reinstalling and system restore. Please help!
disconnect the printer while installing the drivers only connect when softare ask you to connect the cable
Oct 17, 2010 | Canon i9900 InkJet Photo Printer
I cannot get the power button on my Canon i9900 inkjet printer to turn the printer on. It is plugged into an active power source, but when I hit the on button, nothing happens. Does it matter that I have...
The most likely cause is the printhead has gone out. If you can get to it, you need to remove the printhead and try power again. If it comes on you need a new printhead, if you put the old one back in you could destroy the logic PCB.
Dec 30, 2009 | Canon i9900 InkJet Photo Printer
My canon i9900 printer wont install on my Windows 7 computer. What to do?
Instead of trying to use the CD-ROM that came with the printer, access the manufacturer's web-site: http://www.canon.com and click "Support".
Find the latest device-drivers for your "i9900" printer that are compatible with Windows 7. Download them, and install them.
Nov 26, 2009 | Canon i9900 InkJet Photo Printer
Canon i9900 - have to restart every time in order to print
reinstall the printer driver and restart the printer spooler service also . make sure that c drive have more then 3GB memory to run the services .......
Oct 23, 2009 | Canon i9900 InkJet Photo Printer
Vertical fine lines...
Don't have any idea but you might try this link. They have repair manual you can download.
http://printer1.blogspot.com/2009/01/canon-i9900-service-manual.html
It may be in the hardware and if it is you are talking a new control board. Does it print these lines if you print a self test page? If not you might try reinstalling the drivers. You might try different quality modes and see if that has a effect.
Hope some of this helps
Sep 01, 2009 | Canon i9900 InkJet Photo Printer
Printer is offline to one computer but not other.
Ok what you need to do is network the 2 PC's together using a crossover cat5 cable ( can be purchased at Radio Shack). If you don't know how I can explain how to do that also.
Once that is setup one of the PC's with printer driver needs to be shared so the second PC can access. As long as PC 1 is on both PC 1 and 2 can print without issue.
I can be more specific if necessary
Hope this helps,
TankMurdock
Apr 23, 2009 | Canon i9900 InkJet Photo Printer
I lost my power cable cord to my Canon i9900
If you go to Radio Shack they will have everything you need - If not they can special order it for you. I have had to do that before. Hope this helps.
Jan 29, 2009 | Canon i9900 InkJet Photo Printer
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
