Question about Bunn Coffee Makers & Espresso Machines
Bunn SmartWave generating an Error 5 code...
I have de-limed the fill tube, and replaced the pump, but continue to get this error and only about 50% of the normal brew. The fill valve/solenoid seems to refill the tank just fine when using the hot water spigot. Ideas on what to check next?
Posted by Todd M on
gbob59
  • Bunn Master
  • 3,063 Answers
Google item and error code, if no owners manual try:
https://www.manualslib.com
Posted on Jun 29, 2020
Testimonial: "Thanks, I've done both, to no avail. Manual says to de-lime the fill tube, which had been done."
What is Code 33 on Onan Generator Model12.5 HDKCB11506B?
You may be reading the code wrong, Code 33 shows up as blink 3 pause blink 3. This means it has a lower level code fault. To access the real code. Press the stop button 3 times fast within 5 seconds and re-post what the code is please. It may blink pause then blink again, that is the lower fault code that will help diagnose the problem.
Feb 10, 2015 | Onan Generator, 4000W, Gasoline
I have a Kenmore Elite Ultrawave Microwave Hood Combination and am getting an F9 fault code. I hear a rythmic intermittant buzzing, the unit shuts off and the F9 appears on the screen. I have pulled open...
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Nov 01, 2010 | Vacuums
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
May 29, 2010 | Bunn NHB Coffee Maker
Leaking non commercial Bunn 12 cup coffee maker.
I will be happy to assist you with this issue if you would provide your model and date code which are located on the bottom of the unit.
Dec 30, 2009 | Bunn 10 Cup Home Coffee Brewer
Flip Ultra HD Error upon pluging in the camera
I got around this error by moving my library to another location. I created a new folder, then went to Preferences->Library and chose a new location (the new folder I created). Flipshare moved all the data, and after restarting the program the problem disappeared. Not a great solution, a workaround.
Jun 20, 2009 | Pure Digital Flip Video Ultra Camcorder
Code 39 err
Hi, Victor955
This is a Processor Rest Error
This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display.
And if needed unplug for 5 minutes to reset the system
Please remember to leave a rating.
Oct 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
F-9 Error after running a few seconds...
If this is a "SmartWave" branded microwave oven then F9 is an error that indicates an inverter board or magnetron has failed. Either way.. Try this...With the F9 error cleared, start the oven and listen for a ticking sound. The inverter will attempt to 'fire' the magnetron 5 times.(ticking sound). If can hear ticking, replace magnetron....Else in may be a door switch problem
May 30, 2008 | Microwave Ovens
Kenmore ultra elite microwave hood combination
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Coffee Makers & Espresso Machines Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
