My tv has a volume and sound but the screen is dark , what should I do? where should I take it for repairs?
Posted by Joel Silas on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 32,974 Answers
First try a master reset which sets all picture presets back to factory settings.
Google
make model manual
If that doesn't work.
Google
make television repairs near me
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk035dDKtxjKKm0x6MO8N9jnQgvQc3w%3A1593455646866&ei=HjT6XuS7NIXbtQa48IYI&q=television+repairs+near+me
My city has 4 within a 10 minute drive.
Posted on Jun 29, 2020
How to fix TV, Volume started with a humming sound and then screen started to Blink normal to dark ?
It sounds like a rectifier or capacitor may have failed somewhere in the power supply. if the power supply is a separate unit, it can be checked for proper output.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 24, 2016 | Emerson LTDN42V68US 42" Class LCD HDTV
Tv started screeching then screen went black volume and channels ok
Sounds like this:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Of course your TV model may be different and the inverters may be different...but the description points to the same problem.
Aug 15, 2013 | Sanyo 42 in. LCD TV
Tv is dark when turned on ...No sound or picture.But I can see the numbers & volume on the screen
Thats a deflection board issue which has shut the CRTs down the menu pops up so its most likely a vertical issue. You can get the deflection board for that model from www.tvcircuitboads.com
Jul 21, 2011 | Toshiba TZ55V61 55" Rear Projection...
26" Insignia TV, screen is
Go to your menu and choose picture. See if your settings are normal or if the brightness is turned down. If it isn't then it's a problem with the T.V.
May 04, 2011 | Insignia LCDTV26 26 in. Television
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Extreme fluctuation of TV sound leval drives me nuts!!!!
arn't all french movies in whisper and dark screen mode?
I suggest using an amplifier ( yes an amp) reduce the volume on TV to just audible and plug in xtension line to an amp and set the volume on it. It is probably a faulty sound board in your unit. The use of an external amp will control it better by the audio out line.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Transparent French TV Commercials, Volume...
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
