Question about Westinghouse Televison & Video
I have a Westinghouse and and it powers but does not continue the process to picture. ....stays lit but does not show images or sound. Is it the power board?
Posted by mcdarob on
JonSnell Electronic
    Top Expert:
  • Westinghouse Master
  • 31,446 Answers
Model and age may help you get an answer.
Posted on Jun 29, 2020
I have a Westinghouse WD55UT4490 TW-04401-L055A 55" LED that I can't get to turn back on.
Try the flashlight test and see if you can see an image on the screen that way...do you have sound? If you dont have either then chances are its the power board, however sets made by Funai are known for LED lamp failure in the panel
Mar 13, 2018 | Westinghouse Televison & Video
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jun 07, 2013 | Computers & Internet
Power on,but no image westinghouse vr-4625any fix?
If there is sound output to all channels, and oly picture is absent, the backlight inverter board should be suspected.
Apr 17, 2012 | Televison & Video
Unit comes on when pluged in does not have a picture, will not power off unless you unplug it. screen is lit up and has a blinging action
Short in the power circuit will cause it to stay on until the power is removed. The fault you describe is probably down to a fault on the circuit board. The power capacitors could also be faulty, and the lack of an image would seem to confirm this.
I'd suggest that the monitor should be taken to a competent technician for further analysis and possible repair. I'm not sure what you mean by blinging action, but if you mean an audible crackling or noise, this suggests arcing of power to earth. If you mean a flashing screen, it could be the capacitors trying to fire up the HT circuit but leaking to earth as they do so
Jul 22, 2011 | Westinghouse L1928NV Monitor
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Mar 24, 2009 | Westinghouse Computers & Internet
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Televison & Video Logo
29 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
