Question about Samsung Televison & Video
Samsung tv turns off automatically after about 2 minutes of proper function.
Posted by Patrick Kec on
Andrew Taylor
    Top Expert:
  • Samsung Master
  • 32,971 Answers
Normally indicative of overheating
Posted on Jun 29, 2020
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
I have a 43 inch pdp Samsung tv when I turn it on
maybe it is the unit,cable box, dvd,etc.did you go to tv menu or source to see if they display.
Jan 03, 2015 | Televison & Video
How do I set sleep timer on the 6400?
Screen Menu > System > Time > Sleep Timer > TIME
This function automatically shuts off the TV after a preconfigured period of time. You can set the timer up to 180 minutes in 30 minute increments.
From: http://downloadcenter.samsung.com/content/UM/201308/20130813132610569/%5BENG_US%5DX12ATSCF-1.119.pdf
May 07, 2014 | Samsung Televison & Video
The switch button is not function
if you want to risk on phone warranty here's the steps.. open your phone and align your power switch properly, when it comes to worst . you need to sandpaper the side of tha plastic switch! hope that will help cause that's what i do in my samsung galaxy y , switch getting jammed..
Mar 18, 2014 | Samsung GT-S5300 Galaxy Pocket
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Feb 01, 2010 | Logitech Harmony 550 Remote Control
MY Samsung DLP Shuts off after 2 minutes than if I unplug it, it will come back on for 2 more minutes and than go out again. Could it be the Bulb and Ballast failing. I just replaced the bulb a few weeks...
try this..
On the bottom left corner there is a blue switch that detects if the lamp door is properly installed, if you try to turn your TV on without it won’t turn on.
Jan 31, 2010 | Samsung DLP HL-P5663W 56" TV
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
52 HD Samsung tv turns off
I have the same problem with my 56" HD Samsung. It shuts off automatically and then on the power button the word Lamp is light up in green. Sometimes I can turn it back on but other times it won't and I have to wait a bit. It's been embarassing a couple times when people were over for a movie. I believe it might be some kind of overheating problem but would like someone to confirm this.
Jul 06, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
