Question about Furniture
What fails on remote for Pulaski power recliner? Can it be fixed?
Posted by Bud Lewis on
Andrew Taylor
    Top Expert:
  • 33,433 Answers
Contact the maker or a local dealer
Pulaski Furniture: Welcome
www.pulaskifurniture.com
Leather upholstery was added to the line-up in 2019, making Pulaski a full home resource. Ever flexible and responsive to market conditions, Pulaski brings ... ‎Collections · ‎Find a Dealer · ‎Customer Care · ‎About
Posted on Jun 29, 2020
Motor stopped working on both recliners
Hard to imagine two separate motors going fubar at same time. Sure it is not a power issue? Remote control?
Feb 21, 2016 | Starfire Two Arm Theater Recliner...
Our chairs will not swivel properly. What can we do?
SUSAN, WHAT KIND-OF CHAIRS?? TURN CHAIR UP-SIDE-DOWN SPRAY WD-40 INTO BEARING AREA THAT SWIVELLS ,SHOULD FREE-UP AND WORK LIKE NEW, YOU HAVE TO MAINTAIN THESE CHAIRS EVERY SO OFTEN! THANKS
Jan 24, 2016 | Ekornes Stressless Recliner Chair Personal...
Need power supply for pulaski walcott power recliner sofa model 735-403-129
Always check with your manufacturer first.... if they don't carry it anymore. Try Google replacement parts for.......
Mar 11, 2015 | Furniture
Why is the power button for the recliner part slow to act on the home meridian power lift chair?
Here's the manufacturer's phone #
You may find the part needed at Home Meridian....1-800-994-3390 Reviews state that the hand controllers fail a lot and the parts department is slow.
Jul 12, 2014 | Home Meridian Comfort Lift Recliner
What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
Aug 09, 2012 | Furniture
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
Furniture Logo
29 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
