Question about Sharp Office Equipment & Supplies
My Sharp Ar 5516 is showing F2 and when i press start button i shows 40.please help ?? I clean the drum and when i put it on the error happen.
Posted by ahuma funtwo on
Andrew Taylor
    Top Expert:
  • Sharp Master
  • 32,974 Answers
5 Related Answers
Sreelal Devadas
  • 66 Answers
SOURCE: my sharp AR 5516 shows
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
Posted on May 20, 2011
Anonymous
  • 13 Answers
SOURCE: My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Posted on Oct 30, 2008
Anonymous
SOURCE: sharp ar 5320 error code f2
Dear sir.
I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
With beast regards
sayed Masood Osmani
Posted on Mar 10, 2009
Ditchman
  • 22 Answers
SOURCE: sharp ar 5516 copier
Have you tried a trouble clear?
Posted on Jul 12, 2011
pacadams
pacadams
SOURCE: Sharp AR-5516 Copier error code
indicating man icon
Posted on Dec 17, 2012
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
How to fix Sharp Ar-407 Code F2
There are a lot of choices for F2-?? Hold down the Start button to see the remaining digits.
Sim 22-6 will print all jam codes & error codes. It should be a process control code. F2-31 or F2-37, Drum mark or image density. You can execute 44-6. This should show which is out of range. Pull the drum unit out & clean both sensors. Check that the blade is cleaning from end to end that the DM is visible to the sensor.
Dec 26, 2010 | Sharp AR-407 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Dec 16, 2008 | Sharp AR-207 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
