Question about Refrigerators
Is it a good idea to put your refrigerator near a wall?
Posted by Y. Waqif Hussain on
ray gallant
    Top Expert:
  • Refrigerators Master
  • 68,282 Answers
Of course why wouldn't you want it by a wall ?
Posted on Jun 29, 2020
Buzzing Refrigerant Lines
Have someone check your pressures & temperatures in your refrigeration system. Also check the compressor amps with an analog meter to see if the amps fluctuating. There might be something wrong with the compressor.
Jun 12, 2012 | Bryant Heating & Cooling
I see droplets of water in the refrigerator side on the fridge. The fridge also has a little bit of ice forming near the vent.. Its a side-by-side fridge. Any ideas?
i idea is you have a wet frig . caused by wet air .. which is caused by a poor or not a complete defrost. if you have cardboard containers in frig they feel wet not dry and the mosture on the walls shouldn't be there . no frost dryes the air and your's is wet . ck the drain in back of freezer and make sure no ice in back of freezer .. mm
Oct 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
How to turn my microwave on after i put foil in it
You will need to disassemble the microwave and replace the fuse located near the power wire mount at the back of the inside wall inside the opened microwave.
Mar 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fan begins to make noise - then fridge stops.
You have a defrost system failure and needs to be checked.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hairdryer to warm the back wall, 20-30 min, put everything back, turn it back on and you should be good for a couple of days.
Dec 17, 2008 | LG (LRBC22522ST) Stainless Steel
Water is collecting in the bottom of the refrigerator.
assuming this is a conventional fridge.
the drain in the centre of the gulley on the back wall is blocked. push something flexible down it and follow with a small jug of water to make sure it flows away.
good idea to put a small jug of dilute bleach down the drain now and again to prevent blockage
Jun 30, 2008 | GE Refrigerators
Refrigerator is not cooling
Good idea to call a service tech. If it is a compressor problem it should be covered by warranty. If there is frost on the back wall of the freezer section you have a defrost problem. This would not be covered by warranty. If you have a compressor problem it usually is indicated by a hum and then a click from the back of the refrigerator near the bottom.
May 28, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer has layer of frost on back wall - refrigerator not working
Defrost circuit problem, the snow means that your freezer coil is not being automatically defrosted. This could be a problem with the defrost heaters or defrost timer. Also in the newer models a module
controls this operation. Call for service. Removing ice or snow from the back wall is not the solution. The coil behind the back wall is also frozen and no air is circulating.
May 15, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
