Question about Toshiba Office Equipment & Supplies
How can i solve my toshiba e studio452 error code ca10???
Posted by Akter Computert on
Terry
  • Toshiba Master
  • 11,347 Answers
I have a toshiba e-studio 6570C and have an error CA10. how can i solve?
Laser optical unit related service call
Polygonal motor abnormality: The polygonal motor
is not rotating normally.
Feb 10, 2018 | Toshiba Office Equipment & Supplies
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
I have Toshiba e-studio 257 and have an error code C970 on the screen. Can you help me?
C3D2 EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]). C410 Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON. C430 Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state). C440 Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. C450 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing. C4C0 Fuser unit new/old detection fuse abnormality C550 RADF I/F error: Communication error has occurred between the RADF and the scanner. C551 Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed. C570 Communication error between Engine-CPU and IPC board C580 Communication error between IPC board and finisher C5A0 EEPROM communication abnormality (LGC board) C8E0 ADF communication abnormality: The system has to be stopped because the control abnormality occurred C940 Engine-CPU abnormality C970 High-voltage transformer abnormality: Leakage of the main charger is detected. CA10 Polygonal motor abnormality: The polygonal motor is not rotating normally.
These are the error cods list. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 08, 2016 | Toshiba Office Equipment & Supplies
Toshiba washing machine with error code e7-4
Toshiba top washer machine with error code e7-4. What the problem and how to solve.
Oct 08, 2011 | Washing Machines
Error code "CA10"
Hi how are you this is jack .....([email protected]).. my personal ID.
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
The display on my ST-CA10 is out of function
have u solved the display problem?
i have the same problem.
tell me please, if you solved it...what should i do to make it work.
thanks
[email protected]
Jul 30, 2010 | Technics Audio Players & Recorders
I need to how what ERROR CA10 in a Toshiba e-600 mean.
problem in laser unit.most popular in polygun motor
May 24, 2010 | Toshiba E-Studio 3511 Color Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
CA10
It's a problem in the laser unit...(polygonal mirroe)
You need a technician for this one...
Jul 11, 2009 | Toshiba E-Studio 3511 Color Copier
57 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
jasbo
jasbo
CheckitRight
CheckitRight
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
