Question about Westinghouse Refrigerators
Water leaking from inside fridge westinghouse rp423 How to clear drainage pipe ????
Posted by Norman Lewis on
ray gallant
    Top Expert:
  • Westinghouse Master
  • 68,282 Answers
YOU MIGHT TRY A CAN OF COMPRESSED AIR
Posted on Jun 29, 2020
How old is my fridge
most electrolux/ westinghouse products you can use the serial number to identify the production date ( eg: 345978 ) the first number represents the year( eg: 3 45978 )( 1993 or 2003 ) hope this helps
Apr 08, 2014 | Westinghouse Refrigerators
Kelvinator impression series 500 fridge leaks
The other end of the drain is located in the back of the machine. Remove the cover in the back that covers the compressor, condensor fan motor etc, the drain pan is located back there, and the drain is usually somewhere near the fan motor so that the heat from the compressor can evaporate what water does drain. The best way to fix the problem is to unplug the machine and let it thaw for 24-48 hours. Its a pain but its the easiest and most thorough.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Refrigerators
MY FRIDGE IS LEAKING WATER FROM THE BACK. EVERYTHING ELSE IS STILL WORKING
I'm presuming that this is a self defrosting fridge. When it defrosts, the water runs down the back of the fridge inside and collects in a gully, just above the vegetable drawers (If you have them), it runs through a hole in the centre of the gully, down a pipe to a plate which is positioned above the compressor at the back. The compressor gets warm and the water evaporates.
The hole in the gully is probably blocked with debris or mould, as a result, the water overflows onto and into the drawers. MOST fridges have a dip stick like device in the hole, which you can use to jiggle up and down and clear any blockage. If you don't have such a dipstick, a soft wire or bit of plastic tie will do to clear the pipe. Worst case, you may have to pull the fridge away from the wall and check at the back. The compressor, plate and drain hose (about the thickness of a pencil and usually clear plastic) should be clearly visible. Sometimes, the hose gets dislodged so it doesn't drip onto the plate, sometimes the blockage will be at the end of the hose that runs out onto the plate, rather than inside the fridge. You can try blowing into the hose, which should be free and clear to blow through, or pushing a soft flexible wire down the entire length of the pipe to clear any blockages in places you can't see.
Jul 08, 2011 | Westinghouse Refrigerators
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
GE Concept II fridge leaks inside fridge and then out to floor. Noticed that water is dripping in back under freezer where there is a cup-like part. What is the problem?
I had the same problem & I had to clean the water collector at
the back inside the fridge. It was was plugged with residue draining from the freezer. Make sure you clean the drainage pipe behind the fridge also & run some water though the whole system to clean out.
No problems for me after that.
Oct 17, 2010 | Refrigerators
Water is seeping from the front of the refrigerator
There is a blockage from the fridge to the compressor in the drainage line. Easiest way to clear is to locate the compressor and find the pipe above the compressor. Blow into the pipe hard until restriction is cleared. Now clean mess inside fridge resulting from blockage being cleared. Back to normal.
Oct 03, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
How do I empty the tray when full in the back of my model 253.74810400 fridg? Also leaking water from somewhere onto the floor.
the water on the floor will be from the overflowing reservoir at the back of the fridge. i would suggest buying a syringe ith at least 20ml capacity usually you can get them from hardwear shops, and use it to emty the tray at the back. Make sure that the pipe leading from the drainage port to the reservoir (drainage port is located inside inside of the fridge at the back) is sitting inside the collection reservoir and not hanging over the side causing the puddle.
Aug 08, 2009 | Kenmore Refrigerators
Freezer leaking on Kitchen Floor
the pipe which is located at the back of the fridge/ freezer may be blocked or hanging outside of the designated collection chamber designed for this purpose. Unplug from the mains and pull the appliance away from the wall so you can see and get to the back of it. At the back of it you will see a pipe coming out from the bottom of the cooling fins and will go down and the end of it will be sitting inside a shallow plastic collection unit - not covered but open. Itusually is sitting on top of the condenser unit. (this is a large sealed metal structure whic has pipes coming out of it and is the largest item in that area at the back bottom end of appliance). If there is some liquid in it then either move the pipe end into the dry area or emty it out. Sometimes there isnt a collection chamber but the pipe just drips onto the condenser and evaporates - usually on self defrosting certain brand named products but dont know much about that. Use a pipe cleaner to clear out the pipes from inside the fridge out toward the back using that pipe. the drainage hole is inside the fridge at the back and may have some sort of cover or plug in it. remove that and clean it and use the wire or pipe cleaner to shove doen the hold and clear the entrance and exit. Test pipe functionability by pouring a small ammount of water down the drain hole and see it coming out of the back via pipe. If still leaking make sure the vent areas in the back of fridge and freezr are not covered expecially in the self defrosting models. basically dont overload the fridge or freezer coz this causes blocked vents, difficulty derfosting on self defrosters, water builds up and gets out via the tube as it should, but more water than can be evaporated will cause puddles on the floor
Jul 03, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Water drips into refregerator (not the freezer portion)
we have just had our seals replaced and the tech guy that did it also blew the drainage pipes out with compressed air [ a mini air compressor would work ] and now our fridge doesnt leak and gets really cold , the drainage pipe on our westinghouse was at the rear inside near the light
May 25, 2009 | Whirlpool Refrigerator Inverter Box -...
Refrigerators Logo
21 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Ekse
Vincent G
Vincent G
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
