Question about Troy Garden
Troy Bilt Pony. Why is it stuck in drive? - Troy Garden
Posted by Mike Spires on
  • Mike Spires
    Mike Spires Jun 29, 2020
    Don't know where to check for fluid
ray gallant
    Top Expert:
  • Troy Master
  • 71,004 Answers
Check with a DEALER
Posted on Dec 04, 2020
5 Related Answers
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
Anonymous
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    al_kupchella
    Al Kupchella
    • 843 Answers
    SOURCE: broken pull cord on my manual start Troy-bilt Pony
    It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
    Posted on Jun 15, 2010
    sharon
    SOURCE: need belt diagram for Troy bilt Pony.
    hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
    Posted on Jul 09, 2011
    mcgill33930
    SOURCE: Ineed the diagram for a 42 inch deck troy bilt
    We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
    Posted on Sep 08, 2011
    How to adjust drive belt on troy-bilt pony tractor
    pony lawn mower? replace the drive belts.
    Mar 04, 2017 | Troy-Bilt Garden
    Need gasket carbereter kit
    I have been trying to help you. It appears that the "pony" model has submodels as well I will send you this link and please post back with which model is yours. Model numbers are the BIGGEST help I get, because I can research this machine all day and not have the correct carburetor for your exact model. Here are the current Troy Bilt "Pony" Tillers for sale on the net.
    http://www.bing.com/shopping/search?q=Troy+Bilt+Pony+Tiller&FORM=HURE
    Again, please reply. I will get your reply and continue to assist you. Thanks!
    Jul 04, 2011 | Troy-Bilt Pony Garden Tiller
    I have an old troy bilt pony rotertiller no serial tag
    The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
    ballping
    Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
    Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
    May 15, 2010 | Troy-Bilt Pony Garden Tiller
    I have an older Troy-Bilt Pony Garden Tiller witha
    From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at [email protected] and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
    Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
    Troybilt pony wont go into drive.
    Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
    Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
    Troy bilt pony left side tine assembly fell off
    sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
    Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
    Garden Logo
    42 people viewed this question
    Top Troy Garden Experts
    colesmowers
    Brian Anderson
    Dennis Key
    Dennis Key
    Are you a Troy Garden Expert? Answer questions, earn points and help others
