Question about Panasonic Televison & Video
Panasonic remote control N2QAYB001024 with new batteries and iPhone camera test it is not working Replace with? Cost ?
Posted by Mo And Pete... on
Quited
  • 4 Answers
Every month I am earning online more than $8650 by doing a very simply online job from my home. By doing this in my part time I was able to save enough to buy me a new car in just a few months. This is so freaking easy that everyone should try it... Start making some dollars online today by following instructions on this website ==>>
HERE????? W­­w­­w.worknet8.c­­o­­m?
< Please do not copy (?) with url thanks ?? <
Posted on Jun 29, 2020
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
How do i check if the (ir system ) works on my ac unit that i have no remote for so i waste money on a new one??
IR Remote controls use invisible Infra Red light
I often use the camera on my iPhone (in Camera Mode) to see the invisible light.
A computer Camera should work too!
The camera see's the IR as a white light on most cameras
Check it out.
Or the Expensive
infrared viewer
SIMPLEST IR REMOTE TESTING CIRCUIT
Computer Camera
How to test IR remote controls
Make your Own
Remote Controller Tester An Amazingly Simple DIY
Feb 13, 2016 | Audio Players & Recorders
Teac manuals
There are three main reasons a remote stops working.
1. Batteries require replacing (you have done this).
2. The remote is a programmable one and requires programming to the equipment you wish it to operate (you have not specified what the remote is or what it is controlling)
3. By their nature, they end up sat on the table at the side of drinks and often have drinks spilled on them.
If you have a decent phone (NOT iPHONE as they do not work), turn the camera on and point the remote to the camera. Press a button and see if the IR emitter flashes (try a working remote to ensure your camera does not have an IR filter).
If a good remote flashes but your faulty one doesn't, you need a new remote as they are generally not worth fixing.
Sep 04, 2014 | Televison & Video
My panasonic reamot control not work
see the picture. you can use the camera digital or cell webcam. the light LED from remote control must be LIGHT. Otherwise, you must clean the keypads from dust, corrosion.Clean the contacts battery and replace new batteries. Resolder the colder joints.
Jun 29, 2013 | Televison & Video
My remote wont work it says set 1
You can try this simple idea; to re-code the remote to your unit, press and hold 1 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore the remote command to match the unit, and thus the remote should work. Failing that, replace the batteries in the remote with new ones, and repeat the above suggested procedure.
If the remote is triggering 'SET 1' on the unit's display, this simply means the remote code is different to the unit, and hence the remote requires a reset to restore control to it whenever the batteries are replaced. Easy enough to fix, doesn't take very long, and should not cost anything except some new batteries if required.
Apr 28, 2011 | Panasonic DMRES15 DVD Recorder
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Remote sensor does not work on my 27" crt panasonic tv. Is it worth fixing? How much will it cost to fix?(approx.)
test your remote first by placeing in front of a cell phone camera and press any button on the remote and look for a blinking light on the cell phones lcd screen (same as taking a picture) if you the blinking light then your infrared remote sensor is bad inside the tv. part cost about 10 dollars.
Mar 19, 2010 | Panasonic CT2722H TV
My remote control no longer works, even with new
First, test that the remote is actually working. The easiest way to do this is to point it at a switched on digital camera and look at the camera display. The remote uses infra red light which the human eye cannot see, but digital cameras can. As you press a button on the remote, you should see a glow coming from the remote in the camera display.
If it is working, it is probably a fault in your TV - not a DIY fix so take it to a repair shop.
If it isnt working, you'll need a new remote. A genuine Panasonic replacement will be expensive so you may opt for a universal one. However, universal remotes wont support all the functions the genuine one does.
Your choice !
Nov 02, 2009 | Televison & Video
Samsung AS12ABMC A/C (about 3 years old)
heres a clever way i use to check remotes are working. put your mobile phone into camera mode and point your remote control toward the camera while pressing any button.if working you will see a blue light emiting from your remote on phone screen.
Jul 08, 2008 | Samsung AS18A6RB Air Conditioner
Televison & Video Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
