Question about Electrical Supplies
My kde6700ta generator not cranking. What could be wrong?
Posted by Richard Sanderson on
ray gallant
    Top Expert:
  • 68,557 Answers
Power to starter have never seen one to know if they have a solenoid for it or not
Posted on Jun 29, 2020
KIPOR KDE6700TA no oil pressure, while
fill the sump to the correct level
check /replace oil level sensor system
Jul 22, 2018 | Kipor Electrical Supplies
What could be wrong if the generator cranks up but will not produce power?
Are your breakers tripped? Test the power side of the breakers and if there is no voltage there, then the generator may be shot.
Nov 30, 2014 | Honda Dewalt Dg6000 Generator W/ Gx340...
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
Dec 26, 2012 | Generac Power Systems Generac 5525 20 Kw...
Error Codes kde6700ta generator
what code you have???
Aug 28, 2012 | Dishwashers
Armature is turning much slower than blot connected to shaft on motor of an E1-100-D Generator.
DO NOT turn the gen. on any more...you might damage the crank or worse..
hold the crank still by pulling the starting handle and tightening it to one of the red bars(the point of this is to restrict crank movement...you can try anything as long as the crank stays still) then rotate the armature (you might need to dislocate the stator for that purpose).if it got rotated then your crank is fine...and the problem is either with the screw that holds the armature or the armature's screw hole.
that is if the armature rotated easily...if you felt or heard weird things while spinning...then am afraid something inside the engine is damaged..but if the engine is running fine then the last idea mostlikely is not whats wrong.
Jun 07, 2009 | Briggs & Stratton Power Products 5,550...
Car wont start after driving
Ignition module is the likeliest place to look.
Oct 17, 2008 | 1993 Oldsmobile Cutlass Ciera
Electrical Supplies Logo
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
