At the end of the wash/rinse programmes the drum would turn slowly while the pump removes the majority of the water and when the tub is virtually empty the drum will begin building speed over time until the spin speed is reached. The pump remains running until the end of the spin. That is how things usually go.
An automatic washer doesn't drain - it is pumped out!
Your description suggests either there is something wrong with the pump or programmer.
Testimonial: "Thanks for replying Vernon, I will recheck it. Actually it starts the spin cycle normal then after 5 seconds a click sound is heard and rpm is reduced. Checks to the hose finds no water exiting. I then throw the hose to the floor and water comes out. As the tub gets lighter it starts spinning faster. I replace the hose in normal draining position water keeps coming out., ( white soapy) the end... I changed the clutch assembly. Coupling OK. The hose and pump are OK.."
I have noticed that the pump sleeve that fits unto the motor shaft moves from side to side. So I am going to purchase a new pump.
Don't overlook the possibility there is something loose in the tub blocking the drain in the high flow when the pump is running but falls away when the flow reduces.
Strip the machine down. Changed the pump. Same. Only pumps for the first 3 seconds then tub starts to rotate. Next I will check the pressure switch../hose properly. Did a by pass on the lid switch until replacement arrives Learning during knockdown ..
