Question about Sewing Machines
Jade 35. How can I reinsert bobbin post?
Bobbin post popped out
Posted by Gary winter on
umesh bhatt
    Habit-Forming:
    New Friend:
  • 64 Answers
Generally, bobbin post would go in with one push and come out with the next push and will follow this sequence. If it is not going back means the small cyclic gear is broken or not in place. The only way it can be put back is to give some tight packing with a paper or thin cloth piece and next time when you require it remove the packing.
Posted on Dec 08, 2020
ray gallant
    Top Expert:
  • Sewing Machines Master
  • 71,004 Answers
As we would TRIAL AND ERROR METHOD
5 Related Answers
Australian S
Richard
  • 46 Answers
SOURCE: bobbin case pops out
Are you sure it is the correct bobbin case ? If it is check the spindle it slides onto and make sure there is not a bit of lint or cotton on there, this will cause it to not engage the locking latch correctly. Also is the bobbin is not the correct one, or is bent it will not lock in correctly. The other thing to do is put a drop of oild on the spindle the bobbin case slides onto.
Posted on Jul 02, 2009
SOURCE: singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
Posted on Jan 28, 2012
Jimmy
  • 539 Answers
SOURCE: My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
You can turn the screw on the top of bobbin winder tad to right. Also, you may want to try a metal Universal bobbin, but try first option I gave first. Jimmy
Posted on Apr 02, 2012
am1788
am1788
SOURCE: The bobbin case keeps popping the bobbin up when trying to sew. How do you fix this problem?
Hi Kathy it sounds like maybe something is in/under your bobbin case. If you have a manual it should show you how to take the bobbin case out and clean it. Hope this helps
Posted on Jun 18, 2012
sylviaivie
  • 1564 Answers
SOURCE: Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Posted on Jul 14, 2012
I bought a Jade 20 in Nov and just got it out of the box today. I followed the manual to wind a bobbin and it beeps at me when I hit the start button or the foot pedal instead of winding.
You may have to unplug the foot pedal, I don't have this machine but that's what happens with my Brother when I try to wind a bobbin & haven't unplugged the foot pedal.
Hope this helps.
Jan 18, 2018 | Sewing Machines
I have a brother JX2517. I took the bobbin case out to clean it, now I can't get it reinserted properly. I am aligning the arrow and the dot and the thread keeps breaking. Any suggestions?
Vertical bobbins can be a pain to pop back in properly. But first, I'd take out the bobbin and practice without it. Once you get the hang of lining it up and seating it correctly, then put the bobbin in and try again.
I find that a pair of long nose pliers can be helpful - my fingers are so stiff I have trouble manipulating small items and there's not much space to work in either.
Oct 27, 2017 | Brother Sewing Machines
Bobbin won't wind/fill. Post does not spin
Pop an empty bobbin on the thread spool. You need to disengage the motor from the presser foot so that the motor no longer makes the presser foot go up and down, but sends the power to wind a bobbin on the thread spool. Check with your machine's manual, but this is usually done be either pushing in, or popping out a button on the hand wheel. Begin a new thread on the bobbin following the directions either from your manual or as printed on the machine. On my Bernina, I have to push the thread spindle sideways to engage the bobbin winder. Use your foot pedal now and the bobbin will automatically fill up. It should stop when full, then you reverse your actions. eg: push the thread spool back, pop in the button on your hand wheel, insert the bobbin (check with your user manual as to clockwise-anticlockwise, and yes it DOES make a difference!) Re-thread your machine (always with the presser foot up) and make a test stich.
I hope this helps and happy sewing.
Mar 27, 2015 | Juki TL-98Q
How to reinsert the bobbin case on singer 4552
just raise the little lever on the bobbin case, slide it on the metal "post" then let go of the lever.
Oct 08, 2014 | Sewing Machines
How do Iinstall the Bobbin holder in na Singer tiny taylor machine?
I"m assuming that you are asking how to reinsert the bobbin case, rather than the bobbin itself. If you don't have your user's manual, you can download it free at the Singer website. When you do, look on page 19; it has exact directions and an illustration there regarding how to reinsert the bobbin case.
Oct 06, 2014 | Singer Tiny Tailor TT700
The bobbin waser keeps popping out when gets thread behind it. if I clean out thread, how do I replace washer in bobbin holder?
That depends on your machine please provide more information.
This article might help http://ginascraftcorner.blogspot.com/2014/09/love-your-machine-and-it-will-love-you.html
Sep 14, 2014 | Sewing Machines
Deco Bernina bobbin jammed, now bobbin won't work
remove bobbin and reinsert. Re thread needle . Make sure the right size of needle for the material. And check that there is not a wad of fluff under the feed dogs.
Best wishes
Aug 22, 2014 | Bernina Sewing Machines
Clicking noise in bobbin area
it's possible that there is something wrong with the bobbin itself
try changing the bobbin to a different one.
try changing the needle
try cleaning under the needle plate & in the bobbin area for lint.
or the bobbin isn't setting in the bobbin case correctly- reinsert a
another bobbin into the bobbin case & see if that helps
or it could be something is wrong with the hook & hook race-
if the machine keep making the noise I suggest having the machine
checked at a repair shop
Sep 05, 2012 | Janome Sewing Machines
Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Oct 14, 2008 | Consew 206RB
How do I reinsert the bobbin case...
Hi PaQuilter,
Right when you're in the middle of a project - ALWAYS when something goes wrong!
Have you tried turning the bobbin the other direction in the bobbin case? On some machines the direction the bobbin turns can really make a difference.
If you've tried that and still not working:
  1. Make sure the needle is fully up in the needle hole - loosen needle screw, push needle up as far as it will go and re-tighten screw. Drapes are heavy work and the vibration of the machine may have caused the needle to slip a bit.
  2. Re-thread machine from scratch - i.e. take thread completely out of thread path and start at the very first guide from the spool. The thread can sometimes pop out of one or more of the upper guides/paths and this can cause the problem with the bobbin thread.
  3. If the above doesn't cure the bobbin issue, your machine may be out of time and require a Husqvarna tech to look at it/fix it.
Hoping the problem is cured by the above and doesn't require a trip to the sewing machine doctor.
Happy sewing - good luck with the drapes,
Kim & Linnette
Jul 20, 2008 | Husqvarna Lily 540 and 550
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
