Question about Samsung Refrigerators
Our 10 year old samsung rfg298aapn refrigerator freezer started not fully freezing all the time. mainly things like ice cream/popsicles getting soft.
Meat deep in the lower bins are staying frozen. noticed before this happened, we started seeing light frost on some of the items in freezer. decreasing the freezer temp ( now to -6 is working, but it used to be at -2 without issue ). Refrigerator portion is working fine, no cooling issues.
Posted by Ken Ng on
Vernon Taylor
  • Samsung Master
  • 6,548 Answers
I have never owned a fridge freezer so have no experience to draw on apart from a sketchy knowledge of the principles involved.
I just wanted to mention that food remaining frozen at -2 C or even -6 C doesn't mean the food will remain safe to eat indefinitely, in fact the safe life of food at those temperatures will be about the same as in the freezer compartment of the old fashioned fridge - a matter of a few weeks to a couple of months.
The safe and almost indefinite storage of freezer food requires temperature of -25/-27 C
I suggest you obtain service for your fridge freezer...
Posted on Jun 28, 2020
  • Ken Ng
    Ken Ng Jun 29, 2020
    thx for replying. this is the samsung freezer temp settings available in fahrenheit, not celsius.
  • Vernon Taylor Jun 29, 2020
    -2 F isn't cold enough but -6 is almost there, however there is no way ice lollies will become soft at those sort of temperatures so perhaps the cabinet temperature is uneven due to a defrost panel being switched on for too long...
5 Related Answers
francis rivero
  • 958 Answers
SOURCE: GE REFRIGERATOR
can you see thick frost on the back wall or the bottom of the freezer compartment? if you do, you have a defrosting problem.
Posted on Feb 21, 2008
Anonymous
  • 188 Answers
SOURCE: Refrigerator right temp, freezer not.
thermostat might be on its way out try turning it up. make sure the door seal works.
Posted on Mar 26, 2009
Anonymous
  • 103 Answers
SOURCE: my ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
Posted on Jun 01, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: freezer does not keep ice cream frozen
You are having a problem with one of the three main components of the the defrost system. Look into rear of your freezer to see if ice and frost is beginning to build up on the rear panel. If yes begin manual defrost by unplugging and remove contents of freeze. Even better send me the model number of your Whirlpool. That is how I tell you were the problem began most likely. Look around the door frame and inside the fresh food section sea Breeze
Posted on Apr 12, 2010
Anonymous
SOURCE: my side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Posted on May 05, 2010
The freezer won't go under 17 degrees and things like ice cream and popsicles are soft. Refrigerator is cooling fine.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 13, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
The freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
Freezer does not keep ice cream frozen
Apr 12, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Mar 26, 2009 | Refrigerators
Ice cream going soft
What is happening is that ice cream has a lower freezing point that water. Perhaps 5-10 degrees for ice cream. Now, the problem with the freezer is 1 of 3 things. 1. Make sure the air vent coming into the freezer is not blocked. 2. Check the thermostat setting and make sure it is on the coldest setting. You can always bring it back up when you get it colder. The thermostat may be going bad. 3. The freezer may be going bad (compressor or other componnets). If it is older than 12-15 years, then you may be better served getting a new one. This may mark the beginning of the end. Check these and let me know how you do.
Feb 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Refrigerators Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
