Question about Frigidaire Washing Machines
My Frigidaire gallery dish washer is flashing er and 189 how can I correct this problem
Posted by Barry venables on
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
How do I level my frigdaire gallery front load washer
Thank you for your inquiry, friend!
In order to properly balance your Frigidaire washer you would need to seek the help of a professional. Regrettably, this is not a simple DIY job and I would highly recommend reaching out to an expert technician to ensure the repair is correct to prevent future issues. I hope this information helps to some degree. -Matt
Oct 11, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery washer
Hello Eugene - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to fill. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, faulty timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
May 25, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire gallery FGHD2433kw1 error washing clean drying ER s ...
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Aug 23, 2011 | Frigidaire FGHD2433K 24 in Builtin...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire (glws1439fs1) top load washer
If your machine is old means may be brake shoe might be very closes joined make adjustment and correct it otherwise it is a bearing noise kindly replace the bearing along with washer
Dec 24, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
