Question about Liebherr Refrigerators
I HAVE A LIEBHERR CN4003-21. THE FREEZER IA WORKING NORMALLY BUT THE REST REFRIGARATOR DOES NOT COOL.
Posted by CHRISTOS on
ray gallant
    Top Expert:
  • Liebherr Master
  • 68,282 Answers
CALL LOCAL SERVICE COMPANY FOR A SERVICE TECH TO COME LOOK AT IT AND FIX PROBLEM
Posted on Jun 28, 2020
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: freezer freezes up and will
Either you have an accumulation of ice in the duct between the two or a circulating fan has failed.
Posted on Jun 24, 2008
Anonymous
  • 53 Answers
SOURCE: I have a whirlpool refrigerator side by side.The
Please check your door gaskets and in case it is in bad shape do change it immediately. Or even a block in the system could result in partial cooling.
Posted on Jul 06, 2009
ronald_kate_
Ronald Martini
  • 111 Answers
SOURCE: my refrigarator and freezer are not working
Hello, this could be a thermostat or gas problem. If the motor is running fine then I think that your fridge may need regassing. You will have to call a repair man in to help, I hope this helps.
Posted on Nov 07, 2009
Anonymous
SOURCE: Frige not cooling
I have a side by side two door(GSS22JEPHWW) refrigerator. My water dispenser doesn't work but the crush ice and whole ice works fine. How can I fix it?
Posted on Feb 14, 2010
dj_relly999
dj_relly999
  • 4070 Answers
SOURCE: My ice maker stops working
Hi! LOoks pretty much a compressor problem. The compressor may not be working properly that's why when it's hot outside the inside is affected. Im pretty sure that when the compressor is fine the internal won't be affected no matter how hot it is outside. Hope this helps and thank you for using FixYa!
Posted on Sep 19, 2010
The red alarm light has came on on my liebherr Chester freezer but it is still freezing what could be wrong with it?
Items will freeze at 31 degrees F, but normal freezer temp. is 0 degrees F- you should measure the temp inside the unit and be sure it is near 0...
Jun 04, 2016 | Liebherr Freezers
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
My chest freezer is running and feels cool on the inner four sides but not freezing anything. Just keeps things cool, but they don't freeze up.
dear sir ,
first make sure your freezer,s condensore unit is well clean if its good clean then contect to your service technician for refilling refrigarant .i think refrigarant gas is not good amount in your freezer.or freezer has been leak from somewhere.
hope answer the question
thank you
please vote!
Jul 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Apr 06, 2010 | Freezers
Freezer same temp as refrigerator.
Any frost buildup on inside back freezer wall?
Nov 07, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerators Logo
Top Liebherr Refrigerators Experts
Marvin
Marvin
Paul Carew
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
