Question about Samsung Washing Machines
Andre. Check the Water Inlet Valve. Also check the filters where the water hose connects.
Clinton. Door lock issue. Sorry it took 18 months!
Samsung washing machine DE Error code means that the door is open or you may have a fault with the lock. if the door is clearly closed but the machine think it is open, presumably because it's not getting power passed from the door interlock. ... The first thing to check is that the door is closed properly.
Samsung washing machine DE error code - Help and Advice
Posted on Jan 15, 2022
Samsung WA13G7Q1 NOT LOADING WATER
Posted on Aug 21, 2021
SOURCE: I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Posted on Jun 12, 2009
SOURCE: Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Posted on Jul 24, 2009
SOURCE: kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Posted on Apr 18, 2010
SOURCE: we have a samsung j845
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Posted on Aug 30, 2010
SOURCE: de error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
